Anyone check out the new Kef Blade?
Phelonious Ponk
8,677
23
Cool shape. No front-firing midrange driver seems a bit odd.
Tim
JackD201
1,428
1,820
Manila, Philippines
There are Tim. The tweets and mids are concentric units. The pics make the midrange look like wave guides for the tweeter, which, come to think of it, they probably are.
Randall Smith
NC
The midrange does act like a wave guide. If you look at some measurements from some of there other speakers with the same concentric driver, you will see a suck out in the highs. I was told that the suck out was due to diffraction between the tweeter and the surround of the midrange driver. This suck out is only found when measuring the speaker on-axis and isn't present if you listen off-axis.
mep
17
Who listens off-axis??
Phelonious Ponk
8,677
23
Everyone with room reflections. I see the point in accurate off-axis response, but frankly, not if it is at the expense of on-axis response.
Tim
JackD201
1,428
1,820
Manila, Philippines
I wonder what the XO frequency to the woofers are.
fishnchips
Banned
May 8, 2011
97
Concentric drivers make me fundamentally uneasy, be they by KEF, TAD or the latest by Genelec. I understand the advantages of the configuration, but a tweeter's vibration amplitude is very small, in the order of micrometers, nanometers even, at very low levels. How can the loading parameters be defined if the surrounding driver, acting as a waveguide in this case, moves millimeters either way, i.e. a thousand or a million times more than the amplitude of the wave they are supposed to be "guiding"? Isn't this bound to lead to a massive loss of definition, even in the face of benign-looking steady-state measurements?
Mark Seaton
WBF Technical Expert (Speaker & Acoustics)
May 21, 2010
381
141
390
47
Chicago, IL
www.seatonsound.net
Considering that 1/4 wavelength of 20kHz is 4.3mm, it shouldn't be hard to understand why it does not lead to "massive loss of definition." Sure, extremely high excursion might start to cause some issues which could be measured similar to intermodulation, but the ratios of Xmax vs. wavelength have to start becoming significant.
Most over-analysis of hardware by audiophiles is done in extreme isolation rather than in a more holistic manner. A coaxial driver is a non-ideal driver to the idealist, yet quite elegant when well executed to the realist.
fishnchips
Banned
May 8, 2011
97
You are taking the wrong set of data. What you should be looking at is amplitude of vibration or "particle displacement", not wavelength in air. They are two completely different things.
JackD201
1,428
1,820
Manila, Philippines
Please explain how the particles displaced at the source do not affect the particles displaced and colliding at your eardrums if not through wave behavior and the subsequent wavelengths mentioned.
fishnchips
Banned
May 8, 2011
97
They do but that's beside the point. As far as I know, Webster's horn equation presupposes an immovable horn. I'll be happy to be shown a comparable analysis based on a moving horn.
JackD201
1,428
1,820
Manila, Philippines
Classic "pass the buck" Fish.
Mark Seaton
May 21, 2010
381
141
390
47
Chicago, IL
www.seatonsound.net
All measures in audio are relative to frequency, wavelength and period (nothing new). "Large" or "small" are entirely different things at 20kHz vs. 20Hz. "Moving" is subject to the same relative considerations vs. frequency, and this case is very similar to that of a wide band driver. Also remember that in the case of a separate horn, sound produced by a moving horn would not be wanted. In this case the moving "horn" is the cone, which is supposed to make the resulting sound.
Yes, there will be some modulation, but unless you have lots of excursion, the relative amount is very low, just as it is in a wide band driver. This is where 3-4 way implementations with a coax have notable advantages, as the excursion remains relatively low. It is then up to the speaker designer and enthusiast to decide if the very significant spacial advantages are more or less advantageous than a non moving waveguide.
JackD201
1,428
1,820
Manila, Philippines
fishnchips
Banned
May 8, 2011
97
Yes, indeed, and sometimes "small" can actually mean extremely small:
http://www.physics.sc.edu/~kunchur/...isalignment-of-acoustic-signals---Kunchur.pdf
http://www.physics.sc.edu/~kunchur/papers/Temporal-resolution-by-bandwidth-restriction--Kunchur.pdf
The result of ~6 microseconds in the twin papers above is equivalent to a mere ~2 mm.
This too is true. Consider for example an additional factor: A tweeter is typically vibrating at extremely tiny amplitudes. In order for it to work at all, it needs to be mounted on a Newtonian frame of reference that is fixed in relation to the vibrating element. Otherwise chaotic behavior will ensue. I do not know what degree of relative immobility in relation to the frame can be achieved in the context of a concentric driver, but I suspect it ain't much to write home about. This would gravely impair treble resolution as well, over and above the impairment I described in my initial post.
JackD201
1,428
1,820
Manila, Philippines
