Page 4 of 4 FirstFirst 1234
Results 31 to 40 of 40
Thread: The Digital Journey: Assembling a Computer-Based Music Server for Dummies
  1. #31
    Industry Expert Nyal Mellor's Avatar
    Join Date
    Jul 2010
    Location
    SF Bay Area, CA, USA
    Posts
    357
    Quote Originally Posted by garylkoh View Post
    Thanks, Nyal. That was extremely useful.
    I guess that for multi-purpose machines like your Dell laptop, this is something definitely to watch out for. I'll hope that for a dedicated music server, there will be no rogue devices. That may be why on my work laptop, a large buffer in Foobar sounds better, while on my dedicated music server, a small buffer sounds better???
    I actually think it would extend to a dedicated music server, at least one that the end consumer assembles from off the shelf parts, since even on that there may be unintended devices such as wireless adaptors or LAN adaptors causing the issues. One would hope that a server that is bought from a company as a dedicated audio server would have had this checked out and would arrive at the consumer with good DPC latency performance.
    Acoustic Frontiers - Design, Build and Calibration of High Performance Listening Rooms and Home Theaters.
  2. #32
    WBF Founding Member and Super Moderator RBFC's Avatar
    Join Date
    Apr 2010
    Location
    Albuquerque, NM
    Posts
    3,577
    As I stated before, the clicking stopped completely when I minimized the windows of the Amarra player. Apparently, the active meter display takes a lot of CPU to run. My Mach2 Music MacMini server has undergone extensive modifications to reduce unwanted background processes from interfering with the primary function of being a music player.
    Lee
    Lee Aldridge
    I post my own opinions except when posting as a moderator in green.
    http://LeeAldridge.thrivelife.com
    http://www.fightingconcepts.com
  3. #33
    Addicted to Best!
    Join Date
    Sep 2010
    Posts
    1,691
    Quote Originally Posted by RBFC View Post
    Here's a link to the discussion on Computer Audiophile:
    http://www.computeraudiophile.com/co...-Popping-Sound
    Lee
    Thanks for the link Lee, very interesting.
    I notice the initial poster was using a Weiss Int202 (firewire) so it comes back to application layer/resources as you mention and USB CPU utilisation is not part of the issue.
    Interesting they also use an Apple Mac mini, wonder if this happens with their pro models as well - but that does not help you and only helps to narrow down the extent and type of issue specifically around the application layer/resources including CPU utlisation.
    Thanks again
    Orb
  4. #34
    Join Date
    Apr 2010
    Location
    Albuquerque, NM
    Posts
    3,577
    Quote Originally Posted by Orb View Post
    Thanks again
    Orb
    The CPU utilization is by the player software before the USB comes into play. I'll try unplugging my USB cable and watching the Activity Monitor for CPU drain while using Amarra at 24/192. I'm willing to bet it doesn't matter if the cable is hooked up or not.
    Lee
    Lee Aldridge
  5. #35
    Junior Member
    Join Date
    May 2011
    Location
    Thornhill, Canada
    Posts
    4
    Hi Lee
    I found your experience with the setup of your digital system using a Mac and Krell really interesting. Since I own a Krell S1200 too, I followed the same thinking you did and that was to utilise the DAC in the Krell S1200. I have compared My Esoteric CD player (DV50) DAC to the Krell DAC, and found the Krell DAC much fuller, warmer and more definition in the bass. I actually tried the Olive which sounded good, but the remote interface was clumsy. So I bought the Bryston BDP-1 (Mac mini too complicated for me) which is outstanding and also connects to the Mpod remote app. For what its worth I also hooked up the Bryston BDA -1 DAC to the Bryston BDP-1 and fed the analogue signal through the Krell preamp section. However after some comparisons and AB teststing I still preferred the Krell DAC which is just outstanding. So although using the Krell DAC via the coax out from the Bryston is excellent, I too found the issue with Krell's inability to play higher than 24/96 through the coax. I called them and their answer was to use the HDMI cable input which I cannot with the Bryston. So I found your comment that - "I later discovered that the Krell wouldn't accept 24/192 via its coaxial inputs (they are releasing updates to correct this)" - of great interest. Has there been any software upgrade for the Krell? I am not optimistic, but you never know...... BTW the hi res downloads from HD Tracks are great for digital playback.
    Howard Ipp
  6. #36
    Join Date
    Apr 2010
    Location
    Albuquerque, NM
    Posts
    3,577
    Welcome to WBF, Howard!
    The Krell S-1200 (at least mine did, which shipped in Jan 2011) requires a software update that allows the unit to accept 24/192 from MacIntosh computers. Something in the "handshake", I imagine. PC-based sources do not have that problem, from what I've been told.
    Krell is currently working on an update to allow its coaxial inputs to handle 24/192 signals. I will certainly post here when I get news of its availability.
    COMPARISONS:
    HDMI into Krell from MacMini VS. MacMini > USB > Calyx Audio DAC24/192 > Purist XLR > Krell B1 input jacks
    Several of us listened to this comparison, and universally preferred the outboard DAC method. Regardless of who did the switching, or what was playing, this was the constant sentiment. The Calyx DAC (review coming soon) uses the same ESS Sabre DAC chip that the Krell does, so there is a similarity to the sound. The external DAC sounded more harmonically complete and had better bass (levels matched closely, but probably not perfectly). The difference was large enough for all of us to consider it a "no-brainer" in my system. Your setup may or may not demonstrate this same behavior.
    HDMI VS. Coaxial into Krell with CD transport
    Here, we all preferred the HDMI connection. The coaxial input sounded bloated and showed less detail. Instruments, from lute to trumpet, sounded more realistic via HDMI to us. I was using the coaxial output of the Denon 3800 Blu-ray player and its HDMI output for the comparison. I don't own a "high-end" CD transport. It's possible that the software update for the coaxial inputs may change the sonic presentation, and I'll certainly revisit the comparison when I install the update.
    I hope these brief comments were of some help.
    Lee
    Lee Aldridge
  7. #37
    Join Date
    Apr 2010
    Location
    Albuquerque, NM
    Posts
    3,577
    For what it's worth, I'm fairly over the hump on the learning curve for using the Mac computer for audio playback/storage. I've now got about 1/2 TB on my drive, and have left room for the inevitable accumulation of high-res files in the near future (salivating).
    Don't be intimidated, if I can do it, you can too. That's why I detailed the struggle, as I was coming from a near-illiterate position on computers, etc. There is a wealth of help here, and some great people providing it. For that, I am deeply grateful.
    Lee
    Lee Aldridge
  8. #38
    Junior Member
    Join Date
    May 2011
    Location
    Thornhill, Canada
    Posts
    4
    Thanks Lee. Very helpful info.
    I will keep my eye on your posting for that Krell COAX upgrade!
    Howard
  9. #39
    Join Date
    Apr 2010
    Location
    Albuquerque, NM
    Posts
    3,577
    The updates are installed via the rs232 port on the Krell, and your dealer will need a computer that can handle the update file AND adapt to the rs232 port. I can give you the phone number of my local dealer who has the right setup to accomplish the hookup if you need it. They can email the details to your dealer if necessary.
    Lee
    Lee Aldridge
  10. #40
    Junior Member
    Join Date
    May 2011
    Location
    Thornhill, Canada
    Posts
    4
    That would be very helpful.
    Howard
Similar Threads
  1. Laptop vs. Desk top computer for music server
    By mep in forum General Audio Discussions
    Last Post: 12-06-2011, 11:51 AM
  2. What is Your Computer Based System?
    By Bigfish8 in forum Computer Based Music Servers
    Last Post: 01-29-2011, 02:43 PM
  3. High Performance $2000-3000 Digital Music Server
    By Mobiusman in forum Computer Based Music Servers
    Last Post: 01-26-2011, 09:47 AM
  4. Mac Mini or Book + Berkeley USB-to-AES/EBU converter - best PC-based music server?
    By ack in forum Digital: DAC, Transport, Digital Processing
    Last Post: 01-12-2011, 03:57 PM
  5. Forum Posting: on XBMC Audio/Video interface/server for your computer
    By amirm in forum Computer Based Music Servers
    Last Post: 12-25-2010, 05:21 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
