Page 1 of 2 12 LastLast
Results 1 to 10 of 20
Thread: Wadia and power cords.
  1. #1
    Join Date
    May 2010
    Location
    Vancouver, WA, USA
    Posts
    25
    I've owned a nice new silver 381 cd player for just over a year now, and am very happy with its performance. I was wondering if any more experienced Wadia owners have any thoughts and experiences of using specific higher end power cords . Have they in your opinion really give a real and worthwhile improvement (taking their cost into account as well) or have changes generally been small .
    My general thought is that I should just save my money and stick with my Supra Lorad 2.5 which seems to be working just fine. But would like to here what other Wadia users have experienced.
    Thanks Philip. (ps. I have a couple of dedicated ac lines, but no power conditioners)
  2. #2
    Addicted to Best!
    Join Date
    Feb 2011
    Posts
    230
    I've had good luck with power cord changes on Wadia products. Typically I observe a drop in the noise floor which generally results is an improvement in detail retrieval. I've tried Shunyata Pythons (Alpha, not VX) and Transparent (Reference Power Link and Power Link XL MM). Both were good, but I preferred the Transparent cables (more neutral).
    I'm a proponent of power conditioning so I would lean toward an investment there before worrying too much about the power cord.
  3. #3
    WBF Technical Expert (Pro Audio Production) Bruce B's Avatar
    Join Date
    Apr 2010
    Location
    Seattle, WA
    Posts
    3,296
    I had Transparent cords on my 270/27ix as well. Too bad I still don't have them.
    Bruce A. Brown
    Puget Sound Studios
    Stereomojo reviewer
    Seattle, WA
    Even a blind squirrel gets a nut once in a while!
  4. #4
    Join Date
    May 2010
    Location
    Vancouver, WA, USA
    Posts
    25
    I'm a proponent of power conditioning so I would lean toward an investment there before worrying too much about the power cord.[/QUOTE]
    Thanks, if rather than power cords which Power conditioner would you recommend I try.
    A I have a very simple system. Just the Wadia 381 running directly into a Nagra PSA (pyramid SS ) amp. (Speakers are Harbeths.)
    Are there any conditioners with just 2 or possible 3 outputs that work well with both a digital and analogue equipment .
    Or with me having two separate dedicated lines already. Would it make more sense to use two single sourced conditioners , such as Purist audio's Single point power conditioner.
  5. #5
    Addicted to Best!
    Join Date
    Feb 2011
    Posts
    230
    Quote Originally Posted by P.C. View Post
    It really can go either way and the end result will likely depend on your budget. You'll definitely want a solution that will allow you to isolate the 381 from the PSA, but most good conditioners will provide isolation between banks of outlets. With your amplifier connected you'll definitely want something which won't limit current draw.
    I'm currently running a Shunyata Hydra 8 on my front end components which provides 4 isolated banks of outlets. This allows me to separate the S7i from the preamp and phono stage. This weekend I'm going to try a couple of Transparent products (PIR and PIMM) with the analog and digital components connected to separate conditioners.
    Right now I'm only really familiar with the Transparent and Shunyata products. Both are very good and well respected. The shunyata conditioners don't include power cords so you'll need to factor that into your budget.
  6. #6
    Addicted to Best!
    Join Date
    Feb 2011
    Location
    Switzerland
    Posts
    252
    I have wondered about European products? In the states, the Elrod statement power cord is considered non plus ultra, but what about europe?
    I am not sure: Wadia recommends no power conditioning.
    BTW, mine is also a GNSC, I consider it outstanding.
  7. #7
    Join Date
    Apr 2010
    Location
    Seattle, WA
    Posts
    3,296
    Doesn't the EU have balanced power?
    Bruce A. Brown
    Puget Sound Studios
    Stereomojo reviewer
    Seattle, WA
  8. #8
    WBF Founding Member audioguy's Avatar
    Join Date
    Apr 2010
    Location
    Roswell, GA
    Posts
    1,745
    I just switched from BalancedPowerTechnologies (top of the line unit) to the APS1050 (for my front end) and APS2000 (for my Bryston amps). They are battery backed power re-generators generating balanced and "perfect" 120hz 60cycle power. Not only does the battery offer the ability to run without wall power for short periods of time, but just as importantly, allows momentary current draws that exceed the output of the wall since the battery can supply extra power.
    HIGHLY recommended. Excellent sounding.
    One of the better investments I have made in my system for a very, very long time!!
    Life is uncertain. Eat dessert first
  9. #9
    WBF Founding Member FrantzM's Avatar
    Join Date
    Apr 2010
    Posts
    4,056
    Quote Originally Posted by audioguy View Post
    Way to go Audioguy!!
    I haven been preaching Power REGENERATION for now many years in all Audio Forums that I frequent .. Yet audiophiles remain reluctant ...
    Frantz
    __________________________________
    "For me, it is far better to grasp the Universe as it really is than to persist in delusion, however satisfying and reassuring."
    —Carl Sagan
    "Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
    — Albert Einstein.
  10. #10
    WBF Technical Expert (Speakers & Audio Equipment) garylkoh's Avatar
    Join Date
    Sep 2010
    Location
    Seattle, WA
    Posts
    3,420
    Quote Originally Posted by Bruce B View Post
    No. In the US, the cooker circuit delivers 230V using 2 phase. In the EU and Asia, it's 230V single phase. The way neutral is tied to ground is also different in the US and 230V land.
    Gary L Koh
    CEO, Genesis Advanced Technologies
    Please come LIKE our page at http://www.facebook.com/GenesisAdvancedTechnologies
    www.genesisloudspeakers.com, www.absolutefidelity.com
Similar Threads
  1. Wadia S7i
    By AMP in forum Wadia
    Last Post: 08-16-2012, 05:04 PM
  2. Why Wadia?
    By caesar in forum Wadia
    Last Post: 12-19-2011, 12:45 PM
  3. Power cords, a trip into the unknown!
    By DaveyF in forum Cables
    Last Post: 11-24-2011, 06:43 AM
  4. Replies: 140
    Last Post: 12-09-2010, 06:02 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
