Originally Posted by
edorr
If that is the case, the GenVIII would indeed be a better DAC than the ud9004, because it sounds as good on 48/24 as the ud9004 on 96/24. There is an easy way to find out what is going on with resolutions. Just hook up the PWD to the ud9004 and play a 96/24 Blu Ray or DVD-A source. The PWD display will tell you what resolution it is receiving from the ud9004. What would still be hard to explain is how the ud9004 XLR analog is equivalent to coax into the GenVIII on CD sources, which are obviously both 44/16.
By the way, hooking up the PWD to the digit out card will also allow you to verify what resolution the digi out card sends out once you get your CBIII back.
Bookmarks
