The Digital/Analog Dialectic
garylkoh
Sep 6, 2010
5,599
225
1,190
Seattle, WA
www.genesisloudspeakers.com
Cut 4: Oscar Peterson Trio: Nigerian Marketplace – Side 2 Track 1: Nancy with the Laughing Face
http://www.genesisloudspeakers.com/downloads/Cut4_44.wav
http://www.genesisloudspeakers.com/downloads/Cut4_96.wav
Piano jazz, live recording (Red vinyl first press) Recorded in 1982 in Digital
Did I hear a difference? 5 Yes / 4 No
Actual: A was straight-thru, B was A/D/A Loop – Result: 6 correct/ 8 wrong
What difference did I hear?
A: crisper, softer, more “live”, cymbals sound better, preferred (1x)
B: muffled, more resolution, harder, faster, bass more expressive, preferred(2x)
Cut 5: Les Brown and his Band of Renown: Goes Direct to Disc – Side 2 Track 1: Tickle Toe
http://www.genesisloudspeakers.com/downloads/Cut5_44.wav
http://www.genesisloudspeakers.com/downloads/Cut5_96.wav
Big band, lots of brass (all analog, recorded direct to disc, pressed at Teldec, Germany)
Did I hear a difference? 5 Yes / 3 No
Actual: A was straight-thru, B was A/D/A Loop – Result: 6 correct/ 6 wrong
A: Brass not as bright, bigger soundstage, sizzle a lot harsher, more resolution, preferred (2x)
B: bass deeper, separation of instruments more distinct
Cut 6: Minoru Nojima: Nojima Plays Liszt – Side 1 Track 2: la Campanella, Grandes etudes de Paganini
http://www.genesisloudspeakers.com/downloads/Cut6_44.wav
http://www.genesisloudspeakers.com/downloads/Cut6_96.wav
Classical Solo Piano (Reference Recordings Prof. Keith O. Johnson recording)
Did I hear a difference? 8 Yes / 0 No
Actual: A was A/D/A Loop, B was straight-thru – Result: 10 correct/ 6 wrong
A: Mids more forward, rounder, sweeter
B: Highs were clearer and cleaner, more body, more full, greater harmonic density, more resolution, more open, more like real piano, sound outside of speakers, preferred (3x)
garylkoh
Sep 6, 2010
5,599
225
1,190
Seattle, WA
Cut 7: Royal Opera House Orchestra, Alexander Gibson: Gounod Ballet Music from Faust - Waltz
http://www.genesisloudspeakers.com/downloads/Cut7_44.wav
http://www.genesisloudspeakers.com/downloads/Cut7_96.wav
Classical Large Orchestral (RCA Red Seal – probably 2nd press)
Did I hear a difference? 4 Yes / 5 No
A: Orchestra hangs together better
b: Preferred (1x)
Cut 8: Deep Purple: The Mark 2 Purple Singles – Side 1 Track 1: Smoke on the Water (Live)
http://www.genesisloudspeakers.com/downloads/Cut8_44.wav
http://www.genesisloudspeakers.com/downloads/Cut8_96.wav
Rock down the house (Limited edition clear purple vinyl) - my favourite Deep Purple LP.
Did I hear a difference? 1 Yes / 1 No
Actual: A was A/D/A Loop, B was straight-thru – Result: 6 correct/ 8 wrong
A: far sweeter, sounded like what appears to be rear channel info, preferred (4x)
B: scratchy, harsh (2x), edgier, more noise, sharper treble, preferred (2x)
This particular track was played really loud - and the comments may have reflected that the speakers were over-driven.
Cut 9: Ella Fitzgerald & Louis Armstrong – Side 1 Track 1: Can’t We Be Friends?
http://www.genesisloudspeakers.com/downloads/Cut9_44.wav
http://www.genesisloudspeakers.com/downloads/Cut9_96.wav
Jazz in Mono (Direct metal mastered Waxtime re-issue) This cut was played twice. The LP was de-magnetized with an Acoustic Revive RL-30 Mk II prior to playing the second time.
Did I hear a difference? 2 Yes / 1 No
Actual: A was A/D/A Loop, B was straight-thru – Result: 7 correct/ 7 wrong
A: more musical to tap toes to, preferred (1x)
B: more metallic, Louis’ voice got muddied with the bass, spread out better vibrato in voices, more natural
Two respondents commented that they heard a bigger difference post-demagnetization, both got it right the second time (A was straight thru, B was A/D/A loop)
garylkoh
Sep 6, 2010
5,599
225
1,190
Seattle, WA
Cut 10: Hugh Masekela: Hope – Side 4 Track 1: Stimela
http://www.genesisloudspeakers.com/downloads/CutA_44.wav
http://www.genesisloudspeakers.com/downloads/CutA_96.wav
World music audiophile’s reference (45rpm Analogue Productions 180gm re-issue)
Actual: A was straight-thru, B was A/D/A Loop – Result: 10 correct/ 4 wrong
A: more clarity, more detail, more data, preferred (1x)
B: more metallic, preferred (1x)
Cut 11: Edmundo Ros: Heath vs Ros Round 2 – Side 2 Track 1: Granada
Unfortunately, I couldn't find an actual image of the album - it's the one on the lower right hand corner on this attached graphic.
http://www.genesisloudspeakers.com/downloads/CutB_44.wav
http://www.genesisloudspeakers.com/downloads/CutB_96.wav
Big Band in Mono (Promotional mono version of the Phase 4 Stereo)
Did I hear a difference? 0 Yes / 3 No
Actual: A was straight-thru, B was A/D/A Loop – Result: 5 correct/ 5 wrong
A: preferred (1x)
c1ferrari
May 15, 2010
2,162
51
1,770
Hi Gary!
The links aren't working for me :confused:
SeattleJazz
8
Gary, thanks for all of your hard work and getting all of this online! And all the rest of us had fun. Actually, several others provided equipment, helped Gary move his and did the set up at the meeting.
Under "maybe snow" Seattle skies, Gill
Lee
3,245
1,765
1,260
Alpharetta, Georgia
This is an interesting event Gary but I have one big concern. In my listening experience the Minerva DAC is not very reference despite Weiss being an excellent firm. The 202 DAC is much better in my opinion. Could you obtain one of those?
garylkoh
Sep 6, 2010
5,599
225
1,190
Seattle, WA
In stock form, the Minerva is not very reference. But we've compared my modified Minerva to the DAC202, and it's quite a bit better. As it is, the A/D/A loop was quite transparent, I'm sure that with a better DAC, it could be even more transparent. However, I thought that it was transparent enough for most of the listeners.
Lee
3,245
1,765
1,260
Alpharetta, Georgia
That makes sense. What mods did you do to it?
And apologies for the Monday morning quarterbacking. It's still a cool test and I think the quality is very high.
jeromelang
438
66
935
Late to this thread...... :p
Am I right to say the same track (the same portion on that side of the same vinyl) was played twice in each of these tests?
Did no one questioned this methodology?
I'm shocked.....!
garylkoh
Sep 6, 2010
5,599
225
1,190
Seattle, WA
I'm shocked.....!
No, it is not played twice. The phono-stage used had a built-in ADC. We compared the analog output of the phono-stage with the digital output reconverted back to analog with an external DAC. We took great pains to level-match the two.
