Cable for tweeter
jasbirnandra
260
22
923
HI everybody, my speakers are tri- wired and I want to change the cable to the tweeter what will be the effect if I used a much better cable how will it impact the sound.
JackD201
1,429
1,820
Manila, Philippines
It could be pretty substantial depending on the wire installed to begin with. If I were at it anyway, I'd change the wires to the midrange too. The difference would be much more apparent.
jasbirnandra
260
22
923
I have silver cabling of a particular brand for the whole setup except the tweeter and one interconnect from the pre to power amp
JackD201
1,429
1,820
Manila, Philippines
Oh, the tweeter is the only one left? Cool, go for it :D
Speedskater
941
15
368
Cleveland Ohio
Well that depends on:
a] what do you mean by 'better cable' ?
b] what affect are you hoping for?
c] what is the impedance curve of the tweeter?
d] how long will the new cable be?
jasbirnandra
260
22
923
better meaning in construction the effect better highs and more air around instruments length 2.5mts
Folsom
6,032
1,503
550
Eastern WA
Have Dave at ZenWave audio make you a twisted cable for them out of his proprietary gold/silver wire that is Litz style. Litz is when each individual strand has a coating. This minimizes skin effect, which is something that higher frequencies deal with more so.
Sablon Audio
Industry Expert, VIP Donor
May 22, 2015
1,617
1,487
553
A pair of 18g fine silver solid core wires threaded into silk tubing and then twisted will give you a great bang for the buck. No need for terminations, just form a loop with the wire for the binding post. Also use silk rather than cotton as the latter sounds rather dry and muffled in comparison.
morricab
9,537
5,067
1,228
Switzerland
Lessloss C-Marc speaker cable.
morricab
9,537
5,067
1,228
Switzerland
The most extreme example of this is the Lessloss C-Marc, which sounds amazing
Empirical Audio
1,169
207
150
Great Pacific Northwest
www.empiricalaudio.com
This is simple and effective:
Get silver-plated copper (preferably OCC from Japan) in 22 or 24 gauge, black and white Teflon conformal insulation.
Twist together 4-6 pairs of black and white wires and then connect all of the blacks together at one and all of the whites together at one end. Then do the same at the other end. Terminate with fastons or whatever the speaker and crossover needs. Just let all of these hang loosely in the cabinet, do not twist the twisted-pairs with each other.
This will create a high-Q low inductance transmission line that will not impede the HF transients. For the tweeter, this will beat 99% of the ready-made cables on the market. They are all compromises in order to support all frequencies. You only want to optimize the HF in this case.
Steve N.
Empirical Audio
Empirical Audio
1,169
207
150
Steve N.
Empirical Audio
Tango
4,938
6,269
950
Bangkok
The cables of my TAD tweeters and midrange are not difficult to replace. I also plan to switch to SilverGold.
I think the difficult part is to balance the sound if different types and brands of cables are used for drivers, tweeters.
Kind regards,
Tang
morricab
9,537
5,067
1,228
Switzerland
Steve N.
Empirical Audio
Did you see how the Lessloss is made?
Empirical Audio
1,169
207
150
What happens when you change the copper cable to the silver cable for the tweeter
Assuming that you have good silver and that you don't break it in the processing and installation, it should be better sounding. Good silver means OCC and properly annealed and properly handled after annealing.
Steve N.
Empirical Audio
Empirical Audio
1,169
207
150
