Manufacturers invariably advise audiophiles to purchase an entire set of wire products (interconnects, speaker cables, power cords, phono wires) from then, arguing that this maximizes sound quality and avoids adulterating the system's signal paths with inferior cables from some other manufacturer.
Is this true, or are the manufacturers just trying to maximize sales? (It reminds me of the fellow who goes into the store looking only for a new jacket and comes out of the store with a new jacket and shirt and belt and tie and shoes.)
One could argue that if a cable has any sort of sonic signature, then using cables only from a particular manufacturer multiples that sonic signature, and creates some deviation from neutrality.
Based on a particular component's input impedance and output impedance, might it not make sense to evaluate different wires between each pair of connected components? Why should we assume that the optimal wire for each pair of connected components is the wire from a single cable manufacturer?
By selecting all cables from one manufacturer are we achieving some system synergy which mixing and matching cables forfeits?
Do you have all cables from one manufacturer? If yes, why?
Do you mix and match cables? If yes, why?
