Do Sigma NR Power Cables still need to burn in?
Mcbrion
91
15
313
Connecticut
I’ve seen that on the interconnect and speaker cables, burn in is a thing of the past. However I didn’t see that subject addressed for the power cords, specifically the NR generation of power cords. Is break-in time still the same? Several hundred hours? I don’t see any of the modules On the power cords that I see on the interconnect and speaker cable, so I was just wondering.
BlueFox
1,709
406
405
That's not quite true. I installed the Sigma speaker cables a few weeks ago, and let them play continuously for a few days, and they sounded better Saturday night than on Friday night than on Thursday night. Burn-in might be reduced, but they needed time to settle into their new home. :)
I have the Sigma XLR ICs on order so I will see/hear if the same thing occurs.
ken6217
67
16
113
This is from an email that I had received from Grant at Shunyata regarding breakin. It gives a good explanation:
"KPIP is one of the top 2-3 inventions of Caelin's in terms of a performance-added process. Similar to cryogenics, KPIP alters the molecular structure of metals in a profound way. We possess two cryogenic tanks and had been using them for all conductors and metals over the previous 17 years. With the advent of KPIP, these two tanks have been rendered obsolete because they do not make any difference in performance after the metals have undergone KPIP. For example, if we KPIP an interconnect, that product will dramatically outperform the same interconnect that had been cryogenically treated AND broken in and used in a system for two years or more. We tested this in many different systems, ours and our long-time customers, so that much we know.
Settling after shipment will always be required for electronics, speakers and cables regardless of the preparation at the factory and yes, it can take 3-4 days of use to re-set any cable after shipment. For new cables, it will take up to twice as long if no prior conditioning takes place, so a week and sometimes more. Additionally, prior to KPIP, all of our cable products would sound much worse on days 2-3 than they did on day one. WIth KPIP there is usually a "good" starting point, then only a improvement over time with no hangover on day 2-3."
Reactions: Johnzz4
Indy
59
1
138
Thanks for posting that!
