Realism: The room vs. the recording? Why do great recordings sound great in bad rooms?
caesar
775
1,698
Great recordings sound "very good", and even "great" in crappy rooms and setups. Mediocre recordings can sound really good in a great room.
What is that "extra information" in those great recordings that makes "a great room" less relevant?
Rodney Gold
983
11
18
Cape Town South Africa
Caesar , a bad room is a bad room , even with a great recording it will still pollute...the recording that will sound great in a poor room would sound glorious in a good room. As to bad systems , apart from bose clock radios , I havent really heard one muck up the sonics the way a room does.
What makes a great recording is another matter..one could write reams...
gian60
2,508
1,951
343
I have a room with some small problem because no acoustic treatment
Special recording sound amazing
But if I do a good room treatment will sound much better
Mike Lavigne
Apr 25, 2010
12,588
11,663
4,410
there are some recordings which naturally fill any room. so the source of the sound is more likely to disappear. to me this is the characteristic which allows signal path and room distortion to be minimized. to me it's this 'beyond' the reproduction chain' aspect of these recordings which boost them beyond the limits of systems and rooms.
play 'Little Duece Coupe' in any format, on any system, in any room and it works. the reproduction chain disappears. that is an extreme example.....but it's what i'm referring to.
DaveyF
6,129
181
458
La Jolla, Calif USA
+1
Empirical Audio
1,169
207
150
Great Pacific Northwest
www.empiricalaudio.com
Recently I have been able to reduce jitter significantly over my previous products. They already had low jitter compared to other products I tested, but I had no idea that I would hear such a difference with even lower jitter.
The reason that this is relevant to this thread is that the "fill" or "soundstage" that I previously attributed to the recording was actually the result of jitter, filling in the gaps.
Since this revelation, I have revisited most of my familiar recordings Here is what I found:
1) all recordings have better separation and focus of each instrument and performer
2) almost all studio recordings now have a stark difference between the sound of the vocalist and the sound of the instruments. This is not so much because of the mixing, but because of the sound booth that the vocalist was in and the instruments were not. I don't hear any of these effects in live recordings or classical recordings.
3) The "fill" that I used to hear sounded sort of like echo in the venue, but it was synthetic, not real. Now there is jet blackness between performers and instruments unless the venue provides echoes and sound reinforcement.
4) The effect of this is:
a) if your room is properly treated and the speakers are optimally positioned, you get a real sense of the size, shape and echoic qualities of the recording venue. You can almost put a measuring tape on it.
b) if your room is not optimized acoustically, you can get a strange result on some recordings and others appear to be grander than they actually are
Some of the recordings that I used to believe were some of my best are not that anymore, particularly piano pieces. Others that I though were mediocre have suddenly become great.
This is why it's so important to both optimize your room and speaker placement and minimize jitter in your system.
Steve N.
Empirical Audio
4,700
Recently I have been able to reduce jitter significantly over my previous products. They already had low jitter compared to other products I tested, but I had no idea that I would hear such a difference with even lower jitter (...)
How are you measuring jitter? Are you reducing jitter in general or just a few components of the spectra?
Empirical Audio
1,169
207
150
I measure jitter directly using a programmable 7GHz sampling scope. It has a jitter measurement software package.
The jitter that I measure is not a single number, its a distribution over time. I have found this to correlate more to the sound improvements. Usually, if I can see a difference in the distribution, I can hear it in music playback. Because of this technique, it is not showing spectra. It is real-time plots.
This particular change to my products was not a small change though. It was immediately obvious listening to music. My customers that are starting to get this will be posting impressions on my forum on audiocircle.
Steve N.
Empirical Audio
4,700
Steve N.
Empirical Audio
Thanks. Are you referring to this type of cycle-time measurements? http://www.audiocircle.com/index.php?topic=116570.0
Empirical Audio
1,169
207
150
It seems like much well recorded music lacks a ton of complexity where there are only a few sources in the soundstage. Perhaps this has some effect, or lack thereof?
I still find the "fill" to occur when there is any audible jitter present, even small amounts. Just sounds like venue echo. When you play complicated music, it can become musical soup due to jitter.
Try this: If you have a decent track of Doors "Riders on the Storm", see if it has these attributes when you play it:
1) vocalist seems totally disconnected in space from the other instruments, like he is in an anechoic room
2) rain and thunder are way in the background, like 30 feet back - this part sounds like a live recording
3) instruments are very forward
Kind of a mixture of studio and live, with the studio being in different rooms for vocalist and instruments. Interesting recording, but once you hear what is really happening, it's a bit contrived.
If you don't hear these things, and you are playing digital, there is too much jitter in your source.
Steve N.
Empirical Audio
stehno
1,593
458
405
Salem, OR
Very astute of you to catch this as few if any ever do. What you observe is true and is far more true when that well-engineered recording is played back on an extremely well-thought-out playback system.
The answer to your question is simple enough. That "extra information" in those "great" recordings is primarily additional volumes of the recording hall's ambient info captured at and embedded in the recording and you're hearing just enough of the live performance's ambient info to begin to dwarf the listening room's acoustic anomalies.
A well-engineered recording is, well, engineered well-enough to capture even more of the soundstage and recording hall's ambient info than usual. Be it the result of quality of mic's, types, placement, and/or superior engineers, etc. So even if we're talking just the recording's superiority (not a playback system's superiority after addressing many distortions), then a well-engineered recording has captured among other things, more ambient info than poorly-engineered recordings which often times supplies just enough "extra" ambient info to begin to overshadow a room's acoustic anomalies. IOW, there is less competition between the recording and the room.
But since most every recording already supplies ample volumes of this ambient info (but remains inaudible), the real game changer is at the playback system. For example. The closer a playback system is to an out-of-the-box plug'n play configuration, implying very little has been spent sufficiently addressing playback system-related distortions, the less musical the presentation. And the less musical a playback system is, the one playback sonic characteristic that seemingly is more absent than all other sonic characteristics is the volumes of ambient info embedded in most every recording.
And the more this volumes of ambient info remains inaudible, what little ambient info that remains audible at the speaker is in direct competition (and losing) with the listening room's acoustics anomalies. So I suppose for those types, room acoustic anomalies remain high on their list.
But as a playback system is further fine-tuned over time time i.e. sufficiently addressing more and more distortions, the volumes of ambient info embedded in a given recording become more and more evident or audible. Continuing this fine-tuning toward the advanced stages and eventually the ambient info embedded in most any recording becomes so overwhelmingly audible that most / all room acoustic anomalies are completely overshadowed. Even to the point where room acoustics anomalies become essentially a non-issue. IOW, there no longer exists any audible competition between the ambient info of the live performance from a given recording and the room. Are the room acoustic anomalies still present? Yes. But in this scenario they are essentially inaudible.
While many will go to their graves claiming the room and treatments to be the most important component of a given playback system or even just claiming the room plays much of any significance, making such claims is a complete misnomer. To the contrary, for more than 10 years I've put the room at the very bottom of any list of importance. Actually it's so far down, I don't even list it, assuming of course the room already meets certain basic and reasonable requirements e.g. minimal dimensions, enough room for speakers to "breathe", carpeting and pad, a certain symmetry, etc. In fact, the only thing I generally care about a room is a speaker's optimal placement within - a requirement solely for superior bass definition.
Regrettably, with so many focused primarily on the room's acoustics and treatments, they only get further wrapped around that axle because they don't realize they're really dealing with the effects of a deficient playback system rather than the cause.
And as is true with perhaps any performance-orient industry, when dealing with the effects rather than the cause, there's usually little hope for real improved performance.
