Sorry , Khun David you are so smart but I don't understand what you try to say ??Sorry khun Boon but this sounds like a line out of a Soi Cowboy bar, "hello, where you beeen? Miss you so much Tilak..." and you know the rest !
david
david
Very helpful to understand more on this Reference Phono for someone who interestedGuys, if you are interested to have a short read about the phono.
http://audiofi.net/2018/05/kronos-audio-reference-phono-preamp-is-this-the-best/
Louis does not have horns in his home system. His main speakers are Dynaudio Evidence. Amps are Absolare monoblocks, pre amp is some crazy custom passive thing with stepped attenuator and super high quality parts. Source is Kronos Pro/SCPS/Zyx with Kronos phono.
The Kronos phono is a partnership with Trulife Audio in Greece. It's based off the Trulife Argo which looks like this inside. (I own one)
Step up into 12ax7/12au7 with ez81 rectifiers. Teflon board, point to point wiring etc... Trulife is similar to Ypsilon in that they wind their own transformers in house.
In the Kronos version the signal and power sections are in separate chassis. The signal section has a very high quality copper/brass chassis for emi/rf sheilding. input/output is unbalanced (don't think the reference has the convenience XLR out shown in the photo) but also an input straight from the tonearm which eliminates the phono cable/output block. There is a tone control/EQ feature which I think is implemented by dynamically moving the location of the upper/lower RIAA turnovers. There are more changes from the "normal" Trulife model but I am not sure of everything...
