New phono Kronos
Tango
4,938
6,268
950
Bangkok
Louis told me of this phono since it was a prototype. I understand his sound signature. He likes extreme transparency and resolution, super quiet, very open sound with, body, high extension, t ight quick bass but not floor shaken and majestic. Some find his tt a little laid back, but imo that depends on arm/cart on his tt. I think this phono will carry on his sonic signature. He also uses horns at his home reflecting his taste. Maybe thats why this phono is tube.
Kind regards,
Tang
ddk
6,261
4,043
995
Utah
Kind regards,
Tang
There’s also a common belief among many audiophiles that phono MUST be tubes! Or you have a Big Mac ;)!
david
Tango
4,938
6,268
950
Bangkok
david
Ketchup too please!
Tang
bonzo75
22,625
13,645
2,710
London
Louis told me of this phono since it was a prototype. I understand his sound signature. He likes extreme transparency and resolution, very open sound with, body, high extension, t ight quick bass but not floor shaken and majestic. Some find his tt a little laid back, but imo that depends on arm/cart on his tt. I think this phono will carry on his sonic signature. He also uses horns at his home reflecting his taste. Maybe thats why this phono is tube.
Kind regards,
Tang
What horns does he have?
Tango
4,938
6,268
950
Bangkok
Chris F
49
15
240
Ottawa, ON, Canada
Louis does not have horns in his home system. His main speakers are Dynaudio Evidence. Amps are Absolare monoblocks, pre amp is some crazy custom passive thing with stepped attenuator and super high quality parts. Source is Kronos Pro/SCPS/Zyx with Kronos phono.
The Kronos phono is a partnership with Trulife Audio in Greece. It's based off the Trulife Argo which looks like this inside. (I own one)
Step up into 12ax7/12au7 with ez81 rectifiers. Teflon board, point to point wiring etc... Trulife is similar to Ypsilon in that they wind their own transformers in house.
In the Kronos version the signal and power sections are in separate chassis. The signal section has a very high quality copper/brass chassis for emi/rf sheilding. input/output is unbalanced (don't think the reference has the convenience XLR out shown in the photo) but also an input straight from the tonearm which eliminates the phono cable/output block. There is a tone control/EQ feature which I think is implemented by dynamically moving the location of the upper/lower RIAA turnovers. There are more changes from the "normal" Trulife model but I am not sure of everything.
I heard my phono back to back with a nearly finalized version of the reference and the reference was clearly better. I agree with Tango's description of Louis's sonic priorities (the Kronos "house sound") and the phono reflects that. I think the internal step up has been optimized for low output MC with low internal impedance (aka: Zyx) so any cartridge with similar parameters (Lyra SL series, A95/Anna etc etc...) will be ideal. The MM stage is world class of course (tried it for fun with my 1200GR DJ setup) and you could use an external step up if you want/need less gain.
PeterA
12,646
10,898
3,515
USA
back to Kronos phono, i think most of his sales will be to a Kronos holders... the logistics for put it together under their TT are very unique for Kronos...
but - as one said before (i cant remember who mentioned it when it was announced) most of the PP who owned some of the top Kronos must have some really great phono stage to begin with.
I know a Kronos Pro owner who has the CH.
Tango
4,938
6,268
950
Bangkok
Louis does not have horns in his home system...
Hello Chris,
I only said what he told me.. but maybe it's me assuming he has it at home.
Did the prototype you tried has fixed gain without load adjustment? Howmany inputs it offered?
Kind regards,
Tang
Chris F
49
15
240
Ottawa, ON, Canada
Hi Tango,
Actually you reminded me. He has an Altec voice of the theater horn based setup at the factory location. Totally forgot about that.
I don't know the final details of everything for the phono but I think like the Argo it will be fixed gain (24dB step up + 44dB MM) with fixed load via the step up. There is one input into the step up and one straight into the MM stage so two inputs but more like effectively one.
I found this video which shows the back and the case as well:
https://www.youtube.com/watch?v=3zP0Pjm0pjo
I think the Kronos phono has been in the works since the start of 2016 if not longer and Louis is expecting it to be directly compared to EMT JPA/CH P1+X1/Ypsilon etc..
Tango
4,938
6,268
950
Bangkok
Hahaha.. This is so Louis :D. Effectively one input to be used with his Black Beauty. Only intended to have his customers extract most of what he wants his customers to hear.
Tang
MadFloyd
774
1,700
Mass
You have the advantage of system synergy because you have CH the whole chain. You hear more CH strengths than others.
P1 without X1 is like a BigMc without ketchup though.
Tang
I disagree. I don't have the CH chain and the P1 is the best phono I have ever heard.
I passed on the X1 as it made only a very minor difference and in my opinion, wasn't worth the money.
Then again, I'm not a huge BigMac fan. :)
bonzo75
22,625
13,645
2,710
London
And ketchup can take away the main burger taste
MadFloyd
774
1,700
Mass
It was my understanding that Louis recently acquired Magico speakers. I could be wrong though...
MadFloyd
774
1,700
Mass
gian60
2,508
1,951
343
My friend had Viva top preamp and Viva amp Aurora mono
He wanted to change Einstein phono and he tried at home Viva phono and my P1 and Kondo GE1
Bought P1,was really very good also in his system
gian60
2,508
1,951
343
Then also like Tango told,P1 is a perfect match in his chain,but is good in other system,also we tried in the system of other my friend that has ML 32 and 33 and P1 in his system brought big improvment
Tango
4,938
6,268
950
Bangkok
I guess you also dont dip when eating fish n chips then.
Yes, it was a silly analogy:p.
Tang
bonzo75
22,625
13,645
2,710
London
Tang
I hate fish and chips.
Leif S
770
166
180
California
www.vonschweikert.com
He and I speak quite often and he never mentioned getting Magico. But that doesn't mean he didn't. But I know what speakers he uses and he has many different makes and models.
