1 ohm amplifiers
Loheswaran
437
101
273
Out of interest - which manufacturers make amps that drive a 1 ohm load?
thanks
Lohan
LL21
14,430
2,517
1,448
thanks
Lohan
I have no tests, but understand Gryphon, Vitus should both drive those loads. No doubt there are a number of beast amps that will do so.
4,700
daytona600
727
154
955
scotland
1/3rd of a Ohm Sanders magtech , umlimited headroom into any load
GMKF
432
86
135
Munich
Boulder
CH Precision
Soulution
Jeff Rowland
christoph
4,678
4,072
825
Principality of Liechtenstein
My Lamms M1.1 have driven my Scintillas beautifully :cool:
cjfrbw
1,355
1,730
Pleasanton, CA
It appears the new Pass A25 has "one ohm" potential. 100 watts at 2 ohms, 200 watts at one ohm. The hockey puck transistors have very high power dissipation.
RogerD
3,734
319
565
BiggestLittleCity
JackD201
1,428
1,820
Manila, Philippines
cjfrbw
1,355
1,730
Pleasanton, CA
H2O amps were a bit of a boutique class D in the day for Apogees, especially Scintilla. Vince from Sacto (now deceased) was a rabid promotional fan. It seems the modules and topology were changed frequently with constant upgrade-itis, but that was several years ago.
I heard them on Vince's Scintillas, but he was badgering us to fall down in worship. I thought they sounded OK, but not necessarily revelatory.
DasguteOhr
2,435
2,614
645
Germany
Hello,
SAC" THe Amplifer" stable under 0.5Ohm 360Watt Class A Danger hot 100 Grad Celsius at the Heatsink(Name Grave Stones);)
T&A 3000 Mono Amp stable under 1 Ohm
Pb Blimp
518
25
140
USA
The question is somewhat meaningless without a spec for power required. Many amps will drive 1 ohm at low power; even tubes. What are you trying to drive?
christoph
4,678
4,072
825
1 ohm can only mean the dreaded Apogee Scintilla
