Mechanical Diodes? Really?
4,700
16,210
13,670
2,665
I think Mod Squad Tiptoes were sold on the same concept, weren't they?
miniguy
437
168
350
San Diego area
No such thing exists in the context of wave propagation in solid media. The term is most commonly associated with one-way energy transfer in gear assemblies or torque converters. Just try measuring the output of an accelerometer on the top side of a cone subject to vibration at the pointed end.
4,700
It is now audiophile jargon - once a designation has been used for more than thirty years it is considered adopted!
BruceD
1,515
587
540
The Jadis JD1 and Theta Drives adopted this principle as well.
BruceD
trueblue
57
2
8
Yes Ron, you are correct, it was Mod Squard with their Tiptoes, later it was Pin Points out of the Nederlands, Gryphon used in on their first preamplifier in the eighties, YBA, Goldmund and many others used them too. Nobody has a patent on the idea and today there are many versions of them, generally all called spikes and has become a almost mandatory tweak for most.
Don Hills
366
1
323
Wellington, New Zealand
The idea may have its roots in the symbol used for drawing diodes in electrical schematics.
The only time I've ever found spikes to be useful is in preventing speakers and equipment racks from putting flat spots in carpet. They improve the sound by reducing the level of disapproval from the spousal unit.
DaveC
3,899
2,142
495
It's not a principle. It's lore.
I think the issue is it works on paper if you're completely naive and inexperienced in engineering, maybe still in high school... then the reduced surface area of the tip of a spike can be the only variable involved and indeed it would seem to greatly reduce transfer of energy. IRL the tip of a spike digs in and firmly couples with whatever it's sitting on a huge majority of the time, accomplishing the exact opposite of the theory. From what I've seen some still push the idea that spikes decouple but many use them for coupling, which is what they seem to actually do.
4,700
The Goldmund cones are not spikes, tiptoes or similar. They are optimized structures using three type of materials to drain vibrations from the equipment.
Goldmund carried extensive studies on this subject while developing their aluminum speakers - as far as I remember they used a bracing system including brass and steel to drain and dissipate the vibration of the aluminum panels. Their pioneering work was fully described in french audio magazines in the late 80's or early 90's - I am not sure anymore of the exact time - long before others started building aluminum box speakers some decades after.
DaveC
3,899
2,142
495
Well, they are spikes and as such what they will do depends to a large degree what surface they are sitting on and how much weight is on them.
I'm not saying spikes are good or bad, just that they can accomplish very different things, isolation or coupling, depending on specifics.
4,700
Ok, if a bird lands on the top of the Egyptian pyramids we can consider they are inverted spikes ... :D
Just wanted to say that there is lot more in the Goldmund cones than just the shape.
DaveC
3,899
2,142
495
It looks to me like they have some damping material inside and a 2nd material presumably of different mechanical impedance for the tip of the spike... but they are still spikes and this causes a lot of confusion because of the often massive differences between theory and reality.
hifitommy
theories or no, you should have the right to try an item in your system and IF it produces an improvement and not just a difference, then it works. i once sat in on a demo of Aurios bearing based isolators. my thought was that you would place it under something with moving parts like a disc trtansport. nope, it was placed under a Wadia D/A and it slapped me in the face with another 1/2 octave or so of bass.
expectations can be undone in a flash.
DaveC
3,899
2,142
495
That may be true, but the thread title and OP is all about how it works though. Some of us are interested in how things work...
hifitommy
i agree with having an idea about how a product works but online, there are many who fluff on about fairy dust and uneducated or misdirected challenges to the white papers.
long ago, before there was the amazing Randi chipping away at interconnects, i listened for myself for differences/improvements between wire. i found that the newly released Auditechnica wire of Litz was better between the xover and top end (LS3/5As) and the ratshack red/black cheapie passed the lows better than the AT to the infinity monitor jrs i was using as the sub. i had no expectations and would have put whichever wire where it belonged. if no diff had been detected, it would have been a random selection.
we can read about the benefit of using Litz wire but not the bass superiority of the ratshack red/black pair.
nateliv
2
30
An electrical diode, in general, allows current to flow in one direction only....apply the (+) voltage to one side; current flows freely - apply the (+) voltage to the other side; no current flows. There are a number of variations that behave a bit differently, but that is the basic function.
The mechanical diode is similar in that if rotational force is applied in one direction, power is transferred through, if applied in the other direction, no power is transferred through.
stehno
1,593
460
405
Salem, OR
Although a mechanical "diode" would seem to always have bi-directional capabilities, when unimpeded mechanical energy (as with perhaps all energy) seeks first and foremost to travel away from its point source.
Perhaps this gives some designers/observers the impression that the "diode" is directional or 1-way only.
Then again, if mechanical energy's ability to travel is impeded or trapped (think isolation), its ability to travel ceases and its energy will be released somewhere within.
