Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Lampi Super Komputer tubed S/PDIF Digital OUT
  1. #11
    Member Sponsor Addicted to Best!
    Join Date
    Feb 2014
    Location
    London
    Posts
    7,701
    Blog Entries
    10
    Quote Originally Posted by wisnon View Post
    Yes, its been released a month ago. Totally new Power supply scheme (7 PSUs) that took a year to design. Only Linux/Roon supported now, though one is free to use Windows unsupported.
    It's a newer one but not part of a joint Pacific launch? I regard the Pacific launch as much more special and the SK as an expected improvement.
    Audition recordings: Zero Distortion Link; Reference Components: Zero Distortion Link; Own: Lampi GG One-day-to-get: Apogee Scintilla, or a horn (with Tenor 75 OTL ), Preamp to be fit in to suit the gain and drive the power amp. Analog: TBD
  2. #12
    Addicted to Best! Blue58's Avatar
    Join Date
    Jan 2013
    Location
    London, UK
    Posts
    264
    Why not strive for better sound than the Eera sound.
    I was 'enamoured/in love' with my Audio Aero, another tube output Dac, but when I heard good digital it blew it away.
    I think there is a tendency to try to emulate an existing sound when you change components, a sort of longing for the familiar.
    Go out on a limb and try something new. It may give you another epiphany 😉
    Sound Galleries Monaco Server 2015(Roon>Tidal>HQPlayer-Poly Sinc xtr DSD128) > Sablon Audio Reserva Elite USB (data only)/Sablon Audio Reserva Ethernet >
    T&A DAC8DSD > Sablon Audio Reserva Interconnects > Java Triple Shot LDR pre > SupaNova45 DC SE amp > Sablon Audio Reserva speaker cables (pigtailed) > Avantgarde Duo Omega. Sablon Audio Reserva power cords throughout. HiFiMan Edition X V2, SR Blue fuses, Oyaide EE f/s2.0 V2 mains spurs, Akiko Audio tuning sticks, GIK Acoustic TriTraps/panels.
  3. #13
    Addicted to Best!
    Join Date
    Dec 2011
    Posts
    2,284
    Blog Entries
    2
    Quote Originally Posted by bonzo75 View Post
    Exactly.
    its all about the KILLER Pac.
    the SK CAN BOAST OF USING ZERO off the shelf parts though and almost negligible PSU ripple. Regal power.
  4. #14
    Join Date
    Jun 2013
    Location
    E. England
    Posts
    5,394
    Barry, the idea of using my Eera w SK is twofold
    1- maintain my digital house sound but open up streaming options
    2- save money not buying a superfluous dac
    Same budget of Eera mod and SK would get me eg an Innuous Zenith streamer and Schiit Yggy or Aqua La Voce dac w Sablon USB and PCs
  5. #15
    Join Date
    Jun 2013
    Location
    E. England
    Posts
    5,394
    I guess maybe I should rephrase my q.
    Since de facto USB input is superior to SPDIF, but the SK has a superior SPDIF than most, tubed I believe, is it indeed a compromise in 2017 to use a statement server like the SK and restrict its use to SPDIF over USB, purely in order to utilise a cdp dac section that I'm absolutely mad about, but can only be used via SPDIF?
  6. #16
    Addicted to Best!
    Join Date
    Dec 2011
    Posts
    2,284
    Blog Entries
    2
    Quote Originally Posted by spiritofmusic View Post
    No, I get what you are trying to do...plus you have other outputs on the SK, to add a bit of future-proofing as well.
  7. #17
    Join Date
    Jun 2013
    Location
    E. England
    Posts
    5,394
    Wisnon, as someone who knows Lampi inside out, incl the SK, how do you rate using the tubed SPDIF OUT as opposed to the more standard USB?
  8. #18
    Addicted to Best!
    Join Date
    Dec 2011
    Posts
    2,284
    Blog Entries
    2
    I actually dont know that SK and even the older transport personally. I may have heard the Transport at a show, BUT many pals have given me feedback and I toyed with tubing the output of a Universal player I had where I tapped the audio out resistor of relevant audio chip and ran it straight to spdif out, bypassing the messy PCB. I have seen the oscilloscope readings showing the squared up digital signal on the old Lampi DIY blog.
    The Tubed Spdif is way better than normal SPDIFs on Lampi and so I get what you are trying to do. The new SK has SEVEN separate PSU with superb bespoke parts in there and many tricks...it is no joke. My pal builds his own great servers but told me that after chatting with Lukasz he concedes the SK is on another level conceptually.
Similar Threads
  1. Lampizator Komputer vs. Aurender N10
    By Alpinist in forum Computer Based Music Server Forum
    Last Post: 03-10-2017, 04:54 PM
  2. Tubed pre
    By nirodha in forum Spectral Audio Amplifiers, CD transports and Cable Forum
    Last Post: 01-06-2016, 11:43 AM
  3. Lampizator Komputer Changes
    By Alpinist in forum Digital Audio Forum: DAC, Transports, Digital Processing
    Last Post: 12-31-2015, 04:06 AM
  4. What is the best Digital Interface for High End Audio? USB? S/PDIF? Does it Matter?
    By caesar in forum Digital Audio Forum: DAC, Transports, Digital Processing
    Last Post: 05-21-2015, 10:43 AM
  5. How to get S/PDIF from the MB
    By mep in forum Vincent Kars On Computer Audio
    Last Post: 11-07-2011, 02:31 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
