Schopper TD 124
gian60
2,508
1,951
343
Finally i bought an arm for my Schopper TD 124 so i can start to listen
Schopper TD 124 is like new and i have also the non magnetic platter and i found a Koetsu SA 1100 MK VII that i am finding very good
The cartridge i am using an Ortolan SPU A95
The sound is very very good,very dynamic and fast,with good punch and very good bass,also sound very natural.
Bergman sound is more delicate,little more transparent and accurate,but Schopper has the dynamic on mid mid/bass that is beautiful to listen.
Bergmann is better but when i listen Schopper i go on to listen without thinking to connect Bergmann
A great turntable at a not expensive price.
bonzo75
22,620
13,639
2,710
London
You should mention that schopper has SPU and Bergmann has air tight Opus. If you get the Opus on schopper that will changebi like schopper precisely because of the bass, dynamics, and musicality. The PTP lenco has even more bass and dynamics and is extremely large sounding but has to be confirmed if it is as musical. I heard both with zyx, different models.
gian60
2,508
1,951
343
Dear Ked,
you have right
On Bergmann i have Opus 1 that is a super cartridge while on Schopper i have a SPU A95 with 10 hour
After 100 hour with SPU i will change cartridge putting or GFS or A 95
gian60
2,508
1,951
343
On Bergmann i have also a super phono cable made by one my friend.
Is made with copper 7N solid core with mu metal inside for shading and alpha gel for vibration and with special Bocchino jack
gian60
2,508
1,951
343
Here you can see the cable and the difference with other my cable,MIT MA X Phono,that is one of the best cable on the market
bonzo75
22,620
13,639
2,710
London
bonzo75
22,620
13,639
2,710
London
Has anyone heard the STS (greg meltz) restores?
