Vivid Giya G1 vs G1 Spirits
flez007
2,915
36
435
Mexico City
Gentlemen, with the Spirits, does the cross-over sit outside the speakers as a separate box? Or is it an option to have it that way? (I swear I remember reading that in the promotional literature.)
Does anyone understand the pros and cons of this approach?
Xover size can be an issue if it gets inside the speaker enclosure, so vibration control and flexibility. My Ascents sport outbox enclosure for their Xover and might think it is one of the main reason they are so close, or sometimes better sounding, than other new/larger Avalon designs. My two pesos...
lscangus
166
167
150
36
Jim Smith
203
177
948
79
Not sure if this info has been posted before, but Ted passed away last year.
A wonderful person with a wide-open outlook on life...
All who knew him miss him greatly.
sbo6
1,678
605
480
Round Rock, TX
btw; the term 'near field' has to do with the listening position relative to the tweeter spread. if your ears are closer than the distance between the tweeters then you are in the near field. it's not a distance issue but a relationship issue. 'far field' obviously being where you sit farther from the tweeters than the distance between them. and significantly; to sit in the near field typically requires a well treated and balanced room since otherwise the reflective energy will drive you back into the far field.....and if that is happening when you move up into the near field don't blame your speakers......it's your room treatments or lack thereof.
FWIW I don't believe you got the definition of near field correct. Near field came out of recording studios where behind the glass in larger rooms there would be full - sized monitors flanking the console and there would inevitably also be smaller monitors on the mixing console. The monitors on the console would naturally be nearer to the recording engineers and as such deemed "near field". As an artifact of the on - console monitors' proximity to the engineer they were sometimes closer to the engineers than the distance they were apart, but just as often this was not the case especially in smaller studio rooms. So it is a distance "issue" even though I wouldn't call it an issue since it's essentially a preferred listening for audiophiles but a necessity/reality for many studios.
caesar
775
1,698
Jim,
Thanks for posting. Completely devastating news. Ted's spirit and passion really shone through here. Really crushing.
Stay Well
lscangus
166
167
150
36
I am so sorry to hear that. He is one very passionate music lover and audiophile.
