Results 1 to 4 of 4
Thread: USB to AES or SPDIF converter that passes native rate fed to it
  1. #1
    Member Sponsor Addicted to Best!
    Join Date
    May 2010
    Location
    Houston area
    Posts
    238
    I use Roon and HQ Player feeding a MicroRendu as one of my front ends. That provides a great user interface and a high quality USB output signal.
    I need to feed a device that has AES and spdif inputs. Is there a high quality USB to AES or SPDIF converter that passes the sample rate it's fed? I've got a nice Empirical Audio USB device, but it caps out at 192k PCM. I also looked at the Mutec 3+ but it appears to only output at a pre-selected PCM rate.
    Preamps: ADA Reference (multichannel); VTL 7.5 II (two channel)
    Digital: MSB Transport+ Platinum V DAC. Core Audio + MicroRendu streaming; Roon+HQP+FabFilter/Acourate; Trinnov (multichannel)
    Speakers: PRO Audio Technology 2115sm across fronts; 4x 18" PRO subs; 11.4 overall
    Room: Design by Dennis Erskine and Keith Yates. Extensive use of RPG custom bass traps
    Power: Richard Gray 20A UPS and isolation transformer. Triton/Typhon and Sound Application. Shunyata Sigma
  2. #2
    Quote Originally Posted by Brucemck2 View Post
    I need to feed a device that has AES and spdif inputs. I also looked at the Mutec 3+ but it appears to only output at a pre-selected PCM rate.
    Mutec 3+ USB will output at the PCM rate you feed into it. It automatically detects and re-clocks the signal to the input rate, up to 192K. It does not do rate conversions. It will also convert DSD input to PCM, that output will be at a selected rate.
    -Paul
  3. #3
    Join Date
    May 2010
    Location
    Houston area
    Posts
    238
    Pkane, thanks! I didn't see that in a cursory read of the owner's manual
  4. #4
    For another USB to SPDIF/AES/EBU device you may want to consider Singxer SU-1. Very well made, works up to 384K PCM and up to quad DSD when used with a DAC that supports it.
    SU-1 also just passes the input rate to the output, but unlike Mutec, it does not convert from DSD to PCM. This unit is tweaked by many (to add a linear power supply, to improve voltage regulators, replace capacitors, etc.), but works well in the stock configuration.
    -Paul
Similar Threads
  1. USB to AES or SPDIF converter that passes native rate fed to it
    By Brucemck2 in forum Digital Audio Forum: DAC, Transports, Digital Processing
    Last Post: 06-02-2017, 10:51 AM
  2. Amanero now supporting native DSD In Linux
    By Swisstrips in forum Digital Audio Forum: DAC, Transports, Digital Processing
    Last Post: 03-01-2016, 04:54 PM
  3. 15% Storewide Sale at Native DSD - Ends Feb 1st
    By bmoura in forum Digital Audio Forum: DAC, Transports, Digital Processing
    Last Post: 01-31-2015, 06:16 PM
  4. Benefit of higher native resolution-rate then downsampled shown by gaming
    By Orb in forum Audio, Video And Computer Technology Expert Forum
    Last Post: 11-09-2014, 09:11 AM
  5. Best Converter / Ripper to WMA
    By JoeyGS in forum Vincent Kars On Computer Audio
    Last Post: 07-28-2011, 04:19 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
