Looking for acoustic panels for behind my Magnepans
Lee
3,245
1,765
1,260
Alpharetta, Georgia
Hey folks!
Just moved into a new and improved listening room at a new townhouse. I need some foam panels, etc. to break up the back wave on my Magnepan 1.7s. Are there any inexpensive options for doing this? Room is 18x14 with 10 foot ceilings.
I have been using plastic ficus trees but want to get away from the look in the long-term. Any ideas?
Thanks,
Lee
16,185
13,612
2,665
Sonex foam panels are inexpensive.
Bruce B
Apr 25, 2010
7,007
515
1,740
Snohomish, WA
www.pugetsoundstudios.com
Hey folks!
Thanks,
Lee
Lee, I would take caution in this. I moved my Maggies to the studio and they sounded dead. The back wall is 703 fiberglass. I sure wish they would have worked in the studio.
My opinion, you would want something diffusive, instead of absorptive!
bonzo75
22,628
13,652
2,710
London
I have always found absorbers behind panels to make the sound dead. Same with my Summits, and another Analysis audio I tried
twitch
602
245
1,605
SE Pa
assuming you have provided enough space (4' min IMO) I agree
caesar
775
1,698
I ditto other replies suggesting that killing the back wave will kill the liveliness of your speakers. (Yet it's fair to say that some in this hobby may like it like dead, as there is taste for every fetish in this hobby.)
But if you add bass traps to as many corners of the room as possible (ceiling also), such as products by GIK corner traps, tube traps soffits, and others, not only will your bass response improve greatly, but you will also improve clarity in midrange and highs, dynamics, imaging, etc. You will, in effect, have a much upgraded system.
Good Luck navigating this!
4,700
Yes, in this hobby killing corners is different from killing the front wall! :) Diffusor are a good choice for this wall - as they are partially absorptive they will also deal with the excess of back radiated energy.
thekong
253
142
948
Hi Lee, are you sure you need the panels, do you experience any problem with the current setting?
The dimensions of your room look excellent! I would suggest just trying the room as is, and only make adjustments if needed. It may be a good idea to have some light absorbers at the front wall, in the form of thin hanging rugs (those you can get from Ikea will do), instead of the heavy absorbers like foam / fiberglass.
Believe High Fidelity
[Industry Expert]
Nov 19, 2015
1,666
321
355
Hutto TX
ibelieveinhifi.com
I would challenge the dead sound to the speaker and not the acoustic absorption. Panels are not known for their dynamics as their strongest asset.
As a long time panel guy, I was able to get a more dynamic sound from the room when using diffusion on the front wall and absorption for the side wall reflections. However, in doing this I always knew that the extra oomph in the dynamics came from hearing the room rather than the speaker getting better or more alive.
The use of heavy absorption will just exacerbate panels deficiency in the delivering dynamics especially for 1.7. I would go with diffusion for any treatments you end up wanting to add including side wall reflections.
mullard88
948
62
1,588
I had good results with Magnepans by using one tube trap on the middle of the wall behind the Magnepans.
