I have no experiance with these cables. I did understand that Fono Acustica is very similar to Echole in its technique. They both use the same materials and unit halfway the cable I see Echole winning all kind of awards for its qualities on shows. Echole might be less reasonable priced. If you can efford it, I suggest to try the Echole.
