McIntosh C48, Internal DAC, and External DSD Digital Source
Projectman
10
3
20
Sarasota, FL
www.projectsteps.com
I have my C48 connected to a Sony HAP-Z1 and outputting DSD (DOP) over a USB connection. When I try to play a DSD 64 or 128 file the C48 goes silent. It works fine when I play wav and FLAC files.
I have had my Sony HAP connected to an Auralic Vega and had no problems with any DSD file. Of course I use the balanced outputs to the C48.
My question is McIntosh's website only discusses processing DSD files using a Mac/PC via Jriver, is this the only way I can use the internal DAC on the C48 for DSD files? Is anyone else streaming DSD files via USB to the C48 using a device other than a Mac or PC?
The C48 is on firmware 2.10
Thanks in advance for any assistance
Elberoth
2,011
259
1,170
Poland
This preamp's built in DAC can only play PCM files, up to 24bit/192kHz. Anything over that, including DSD files, has to be downconverted for playback.
For native DSD playback you need to get C52.
Projectman
10
3
20
Sarasota, FL
According to this excerpt from a document on McIntosh's website to help setup your PC/Apple computer running JRiver software the C48 can process DSD-DXD files.
" Purpose of this Document: To add the capability of playing DSD-DXD file types over McIntosh 32/192 USB 2.0 DACs as used in C48, C50, C2500, D100, MHA100, MXA70, MA5200, MAC6700, MA6700, MA7900, MA800..."
Kal Rubinson
2,362
705
1,700
NYC
www.stereophile.com
As has been pointed out, the C48 cannot handle DSD at all and any DSD files need to be converted (either in bulk or on-the-fly) to PCM at no more than 24/192. PCs/Macs using JRiver or other music programs can do this. I do not know if the Sony HAP-Z1 can be configured to do this.
Projectman
10
3
20
Sarasota, FL
The C48 can absolutely handle DSD, but I guess it depends on the source and whether the C48 is USB2 compliant. Jriver outputs DSD to the C48 which means the C48 can process a DSD stream as McIntosh states. My assumption is the C48 isn't USB2 compliant which means it could accept a DSD stream from any device via the USB port. My understanding is if the C48 isn't USB2 compliant than it can only accept a DSD stream from a MAC/PC/LINUX as they have the proper drivers.
Elberoth
2,011
259
1,170
Poland
C48 DOES NOT accept native DSD and neither does C50, C2500, D100, MHA100, MXA70, MA5200, MAC6700, MA6700, MA7900, MA8000.
The aftermentioned components can 'play' DSD files ONLY AFTER the DSD is externally decoded to PCM 24/192kHz (max) stream. This is not native DSD playback and will not work with components that lack DSD to PCM processing feature.
Projectman
10
3
20
Sarasota, FL
Thanks for the clarification. I obviously was wrong. The documentation on McIntosh's website confused me. I didn't realize that the JRiver application was converting the DSD to PCM. I understand now. I currently have an Auralic Vega between the SONY HAP and the C48 and I was hoping to sell the Vega and recoup some money by going straight from the Sony HAP to the C48. I have a few hundred DSD files so I guess I will have to keep the Auralic for the time being or think about converting my DSD files to .flac.
Again, thanks for having the patience to put up with my ignorance. I wished I would have done more research before buying the C48. Thank goodness I bought it used for a pretty good price.
Elberoth
2,011
259
1,170
Poland
You may sell the C48 and Vega, and get the C52 instead.
Projectman
10
3
20
Sarasota, FL
A little out of my budget. Probably consider the C47 instead since it has the same DAC as the C52
steve59
356
112
150
bump, i bought a c49 today and i cant get anything out of the usb input. roon nucleus has all the necessary software to 'see the dac, but it don't. any suggestions would be great.
steve59
356
112
150
I guess after 6 years it was a stretch to hope for suggestions
