AT ART 1000 ~ Any users yet?
Uk Paul
516
183
955
UK
Ah yes, they were the speakers I thought i'd seen somewhere here, very niceley done Stampy. Out of interest, which veneer did you use, possibly eucalyptus? Thanks for adding the pics, it is great to see your work..
As an update, I did just yesterday receive at last a response from AT re the art9. Am now working out how to resolve the issue which I would like to do as the Art 9 is a good sounding cart for the cost. As I am about to finally get to build the final version of the plinth I will be adding an SME V / London Reference combo, so then the SAEC with it's detacheable headshell can be swapped between the Art 9 and a higher end MC, options here are still wide open though.
stumpy
9
I honestly don't remember the name of the veneer. I do remember exhibiting at an audio show and meeting Masataka Tsuda who was displaying a solid state se amp, back when we were both, um, a bit younger...as I see you are a dealer for CF.
Uk Paul
516
183
955
UK
Interesting, yes, Masa is still very busy with his pieces, and still showing in the states each summer..
Uk Paul
516
183
955
UK
So as an update; I will most likeley sell the ART 9 for a DV XV-1s re built by AJ VdH. Having spent heard one over the past week it really is a wonderful cart. This will probably live on the SAEC 506.
AT did eventually respond to my emails, and suggest that the 87 degrees of the stylus tip is normal and intentional. It does however sound considerably better at just over 90 degrees which is the max angle I can acheive.
Stump
155
76
935
Audio-Technica ART1000 Direct Power Cartridge
I run clearaudio TT and cart.I am considering the Art 1000 but unlike the Clearaudio cart the needle has very little overhang and Im concerned it will not clear my record ring at the start???Can anyone confirm it will clear the thickness of the record ring?
Stump
gian60
2,508
1,949
343
Hi Paul
I bought a Saec 506 to put on Torqueo that will arrive end of jenuary
I saw you have 506
It’s a good arm?
Are you happy with him?
morricab
9,465
5,035
1,228
Switzerland
Thanks, that's an interesting post. I suspect that the main problem with matching a SUT and a tube preamp with the ART would be you would likely loose the midrange purity...due I think to the insertion of an SUT!!
Unfortunately, the ART does not put out enough voltage to drive a tube phono stage without an SUT...which leads me to one of my pet peeves...ultra low output cartridges....Ugh!
Yes, agreed. If it is too hard to get the best out of a cart then a "lesser" cart with higher output and a better phonostage, IMO tube, will get better overall sound. That said, there are transparent SUTs but they are pricey...
Uk Paul
516
183
955
UK
Hi Paul
I saw you have 506
It’s a good arm?
Gian,
SAEC 506 is a very good arm, and yes, I am happy with him;)
Where did you get yours from? If you can, it is worth getting the heavy AS600e mounting nut, assuming Torqueo can accodate it underneath..
I also have SME series V but have not installed it yet, this I will do next year.
gian60
2,508
1,949
343
I bought from Torqueo
Torqueo has some 308 and 506 in stock,they buy in Japan and restored the knife and become like new
Torqueo for his turntable suggest Saec 506 and Ikea 407.
Torqueo prefer a little 506 on 407,but told both are very good
Uk Paul
516
183
955
UK
Gian,
Looking forward to you receiving the 506 and Torqueo, not long to go now..
You will notice on 506, optimum geometry for 12' LP is different to SAEC suggestion, 506 was designed for broadcast and to excel at 7" single replay, so Stevenson is closest geometry aligment. But, increasing the offset from 14.4 degrees to 18.3 degrees gives better sound across 12" LP, so cart will be not aligned with sides of headshell but slight twist inwards, do not worry, and check with Torqueo their set up too, let me know what they suggest please? What cart will you try first? and will you try SPU for me? Thank you Gian..
gian60
2,508
1,949
343
Many thanks,i will check with them.
I will try first SPu A95 and SPU Synergy and then Coralstone Diamond,could be sauces good for Koetsu also
Regards
