Or is there? Admittedly, in my record collecting, buying records that turns out warped ranks among the top 2 headaches, the other being scratched records. Mind you, both problems can turn up 'after' buying the record in satisfactory condition. In time, improper storage and heat can warp your records right inside your room though they were bought flat. Also, one might accidentally drop a pristine record while about to play it, thereby causing a scratch.
That said, scratched records have no cure. But warped records, there might be hope. Might, as most methods known are 'touch and go', meaning there is always a risk that the warped records will get worse after the cure. Some 'cures' I have tried are baking in oven in low heat (sandwiched in glass sheets) and long minutes (to me, always a disaster), heating under the sun sandwiched in glass sheets as well (this one worked well for a couple of years until global warming kept our sun from heating normally), heating under light bulb (disaster as well), using a friend's de-warping unit from Air Tight (2 ok, 2 disasters), and of late, simply stacking the warped record vertically in my shelf 'as tight as possible' for about 2-3 months. (The last has the best success rate as there is no risk of further destroying the LP). Any other experiences?
