Review - S5 MKII
BlueFox
1,709
406
405
Thanks. The rack weighs 500 pounds empty. Great for vibration control. I guess I could pull them out to the edge of the rug, but I haven't tried it. Maybe some night after they are totally broken-in I might try it.
scouter
241
4
Wrightsville Beach, NC
Bud,
My S5s are in almost the same location from the back wall as yours, (maybe little further out, but not much) and tube traps in the corners behind the speakers will blow your mind! I didn't believe it until I tried them, and my wife was raising holy hell when they arrived, but honestly, even she had to admit she could tell a difference listening from the ADJOINING room. The amount of "quietness" for lack of better word is incredible. No they don't look good, but it was equivalent to adding a much better component in my system. All in all, nice looking set up. Don't blow those tweeters!:)
BlueFox
1,709
406
405
The problem I have is that the right has both an open room to the right, and it is next to a hallway leading to the back of the house. I put the picture currently behind the right behind the left, and it skewed the soundstage to the right. Now it is balanced. I will try little tweaks here and there, but I suspect things will be pretty much as is.
PeterA
12,617
10,811
3,515
USA
Bud, Have you tried separating the XP20 control unit from its power supply? I notice that the PS is up on Mapleshade footers which try to provide a path to drain the energy out of and away from the unit while the control unit is on its rubber feet which isolate it from floor borne vibrations but keep the vibrations from exiting. There may also be some electrical interference between the two while stacked. You could try placing the control unit on the top shelf up on the brass footers to see if it changes the sound.
Those speakers look great.
BruceD
1,513
582
540
Hi there, Nice setup:b--I tend to agree with PA--I'd certainly try the XP20 placed away from the "sensitive" area--
I noticed a significant difference in my own system when I moved my CD555PSU 3ft from the Player.
As a further thought--the Hydras could be in the "hot" zone
Anyway I'm sure you have done your due diligence re these placements -so just my observance --no worries:)!
Good listening,
BruceD
BlueFox
1,709
406
405
The cable connecting the two XP-20 chassis is not very long. I'm not sure it will even be long enough to be either side by side, or above where the SACD player is. Then again if I did separate them I could lower the shelf above it, and that might work. I rarely use the SACD player so I could remove it. I might give that a try someday. My next tweak is sending my HT Triton v2 in for the v3 upgrade. When that returns I will swap out the stereo Triton v2 with it, and find out if that makes a difference.
Bobvin
1,709
3,044
665
Portland
www.purewatersystems.com
Bud, bamboo hardwoods? Your flooring looks amazing.
NorthStar
24,305
1,323
435
Vancouver Island, B.C. Canada
I like that painting Bud; it reminds me a little of that 3D flick...'Doctor Strange'.
You have an awesomely good looking setup, and loudspeakers...everything is...magic. :cool:
The carpet seems to match the painting...magic ? carpet ride.
BlueFox
1,709
406
405
Thank you. No, it is some kind of synthetic fake wood, but expensive since it is waterproof. The color is interesting and depends on the light as it has a grayish tint. The benefit from an audio perspective is that it sits on a concrete slab, and that sits on the ground. No crawlspace under the house to introduce vibrations into the system.
BlueFox
1,709
406
405
I bought that picture to go behind the rack, but it ended up behind the right speaker. Amusingly, it was the second one I bought. Before I hung the first one I placed it in front of the fireplace, which has glass doors on the insert. Anyway, the sound improved a bit, and I like the way it looks, so it will stay there. Now I need to buy a third painting. LOL
Dr Strange is on order. Unfortunately, there isn't a 4K UHD version.
cjf
454
105
948
Hello, speakers and setup look great.
I'm curious if when you received your new S5MkII's if you happened to notice if the spiked feet on them were fully removable or not?
I was surprised/annoyed to find out that the spikes on my S3's were perm attached to the outriggers. Well, that's probably not 100% accurate. If I wanted to take a torch to them and melt the Locktite while they were crimped in a vice I could probably remove them but thats not going to happen.
Just curious...Thanks
BlueFox
1,709
406
405
They arrive on rollers, which you remove and then add the spikes. I don't remember if there is another option other than spikes to install instead.
BlueFox
1,709
406
405
Bud, what is your listening distance from chair to tweeter? It looks near field from the photo.
Correct. It varies between 7-8 feet, depending on mood. The room is 16' wide. Maybe tonight I might try 9-10 feet back.
BlueFox
1,709
406
405
Not sure what happened between last night and tonight, but the sound is a touch better now. The bass is thumping clearly and cleanly, and the detail in the mid area is even more revealing. Songs are coming on and I am going 'What is that?' LOL. I love it when these experiences occur.
I suspect the speakers are adjusting to their new home, but the same thing can be said of my two week old Triton v3. Whatever is responsible, the end result is a big 10/4 good buddy.
