esoteric players need at least 200 hours break-in. need many hours on each filter setting as well.
enjoy!
How do you like the HRS dampening plate(s)???
It has lowered the noise floor. Better focus with individual instruments. The only issue is two are needed for the K-01X. The top cover is plastic, and rings when tapped! I had used my other plate to confirm my findings. I have ordered another from Legend Audio.
Hey Zephyr, I should be more specific. I was incorrect about the cover being plastic. It's metal after all. It is a cover plate that is attached securely. I noticed the change in dampening of that cover when tapping the cover with the plate on and off the top of the unit. I am certainly not the only owner using them. Have you seen this photo before? It is another K-01X owner using the damping plate.
I too use the HRX DPX with good results . If only one , try it diagonally across . It will dampen a larger surface area then that when horizontally across .
How is the K01x settling into your system? It's a fantastic disc spinner.
Hi Dan, It is settling in just fine. I was in an SACD mood today. Then K-01X has around 200 hours on it now. If the recording was mastered correctly it is amazing the amount of detail along with analog type warmth and feeling being reproduced.
