Looks just sooooo gorgeous !
But it might sound pretty bad. You would overlay a prominent acoustic on all the acoustics captured in the recordings to be reproduced. A 'double acoustics' event if you will. A rather messy affair.
Some dry recordings might sound somewhat decent.
Hi
On a scale from 0 to 10, i'll give this one 8.5 for Marketing. Pictures are gorgeous.
I would like to know a bit more about the Avant Guarde Basshorn.. have the feeling that massive amount of EQ is used in it. Horns seems small to go very low without substantial EQ ...
b75
I believe in distributed subs.. Googling the AG Basshorns, these are DSP-controlled Basshorns. Not saying they aren't good. Simply that there are better ways to build subwoofers and that my hunch was correct they are EQ'd. Of course once a person decides that Basshorn are necessary so that the entire system is horn then that is fine.
I don't care enough about the Grand to travel to listen to them. I had Apogee, I have had planars for most of my audiophile life and do believe that cones and horns/CD have arrived.
Never heard the Western Electrics so can't say much about them. Heard the JBL DD9800 (or such, the 3-way model with two 15 inch and horns integrated with the cabinet ) and it sounded sublimely good. I will likely go JBL or Geddes.
AG are good but I don't consider these to be the best horns available that I've heard . There are better horns IMO both objectively and subjectively and at less loftier prices.
