Little Help from Google Translate
Welcome to www.tonbandspule.de
We are pleased that you have found us
We manufacture high quality reels of tape on studio technology level
the core in the center is not an ordinary plastic core but precisely milled aluminum,
so is a very precise concentricity guarantees
We do not like BOREDOM on the tape machine
most of our coils 2farbig and many coils are ANDERS up and down
and therefore belongs to each coil a valent, decorative aggregate carton
Tape spool diameter outside 300 mm
Buy with this offer a tape spool / empty spool in a carton valent
for studio tape machines (for example, STUDER A80 or A812MK2, A820, Telefunken M15A et al)
Please note: not fit due to the outer diameter of the usual home tape recorders !!!
the coil in this package includes the following features:
- Cover plate "red" eloxial
- Rear plate black anodized
The back plate is slightly offset mounted "pinwheel" design
but can also be remounted congruent (the 6 holes then exactly one above the other)
if you give a hint to us when ordering in "message to seller"
get the coils also like to "congruent" we supplied assembled
.... Tastes obviously but very different ....
- Made of 1.2 mm aluminum
- Core "NAB" machined from solid aluminum and anodized black for 1/4 inch tape / "laces"
- Come in a white carton valent solid board, cover the outside with
quality decorative cover based / inside white paper
- The items of our coils are high quality anodized with rich colors
small color deviations in the anodizing process, and must be accepted.
Warning tapes and blank tape reels should be stored cool and dry.
Tapes and coils please no longer direct sunlight (UV) suspend.
- Both our coils as well as the cartons are 100% made in Germany
__________________________________________________ _______________________________________________
You need more ... / different color combination ... / would you like your own layout ...
- Ask us, in appropriate quantities much is possible
like we finished (where techn. doable) exactly "your" reel
and so clear: the folding cartons's in different colors, some even from stock
