Hi Tang,
also i had a MA X Phono and i sold buying this Kuro
For me and in my system the sound is much better because it seems pass more signal and sound is more big,open, transparent,natural,better in every parameter.
Consider that MAX is one of the best cable.
I open a thread in cable,Italian top cable Kuro,so you can see a brief description of these cable.
I am buying all for all the system,including power distributor.
Consider if you buy directly from my friend of Kuro price of this cable is less that half price than MIT,price in Italy,considering only the jack cost around 500 euro each and are four.
If you would like to try some of his cable i can ask my friend to delivery to you to try,then after you did agreement with him for price,if price for you is ok,you try for one month and if you like you send the money to him,otherwise you send back the cable.
Only problem of this cable are heavy and too rigid and he is studying to do less rigid,using inside cotton and silk
Regards
