RPM: Check turntable speed with your iPhone?
ack
May 6, 2010
6,774
1,198
580
Boston, MA
Here's an interesting app https://itunes.apple.com/us/app/rpm-turntable-speed-accuracy/id1030889902?mt=8
You set it on top of the platter, and it uses the phone's gyroscope to calculate speed. I had high hopes for it, but it told me my table was too fast, and then I realized that even on steady surfaces the gyro shows a 0.25 +-0.01 rpm rotation. I don't think I can compensate the reading by subtracting 0.25 from it, because I am not convinced the gyro's error is constant. See what you get...
Sample screen:
ack
May 6, 2010
6,774
1,198
580
Boston, MA
It depends on the size of the iPhone; my 5 does not disturb the cartridge in the outer grooves.
ack
May 6, 2010
6,774
1,198
580
Boston, MA
In science, if your measurement approach interferes with the object under evaluation then your measurement is flawed, plain and simple. The iPhone is not any different. I was just curious and mostly interested in the speed variation, and it shows the same +-0.01 variation as still. So I take it for what it's worth - just another data point.
amirm
Banned
Apr 2, 2010
15,813
37
Seattle, WA
I wouldn't hold the still measurement against it. We need a calibrated system to compare it to. Doesn't anyone have a turntable with its own internal measurement display?
beaur
Fleetwood Sound
Oct 12, 2011
460
166
950
60
Brooklyn
The Feickert Platterspeed app and tone record have worked well for me. I tested it with a handheld rev meter and it seemed spot on. Plays a tone you pick up on your phone with the app.
Mosin
[Industry Expert]
Mar 11, 2012
895
13
930
I thought the original RCA Victor LP rotation speed was 33 1/3 RPM, so 33.29 rpm seems pretty close???
That's close enough, but Ack nailed it.
Any tool is useful only as a guide for coarse adjustment, if it cannot show the consistency of a given rotation. Records were made at various speeds, but close to 33-1/3, so that is pretty much a target point. The main thing is that your turntable doesn't waver in its spin, and it is absolutely constant no matter what width of groove is thrown at it. The devil is in the details, as they say.
awsmone
1,616
514
435
Canberra Australia
i use free guitar tuner app and any test record this tells me the exact frequency which i check against the test track frequency the ultimate accuracy.... correct pitch :)
sombunya
133
8
325
I have that app and I've used it. It's free and it seems to work. Again, it's free. What do you want?
I've compared it to built in strobes and it's on. I know, arguments can be made against line voltage frequency and that means a strobe must be built.
My Rega RP3 runs a bit fast, almost 34 rpms. My Music Hall MMF 9.1 is spot on.
I'd think with all the crazy expensive and very exotic TT's around here there wouldn't be much need for it.
4,700
European users sleep calm - they do not need fancy strobes to adjust their turntables. I use a quartz strobe since long and have found that it agrees with my 50Hz 230V LED lamp that sits close to the turntable. Just found why. In Europe we have a site that constantly monitors AC frequency with five digits and I saw that mains frequency is usually very accurate - most of the time better than 0.05% - equal or better than any professional reel tape machine.
If you are a very rigorous person you can see the exact mains frequency online and apply a correction to the strobe reading. See http://www.mainsfrequency.com/
ack
May 6, 2010
6,774
1,198
580
Boston, MA
ack
May 6, 2010
6,774
1,198
580
Boston, MA
4,700
