Amarra Software or other comps
MarinJim
888
2
As Amir said... MSB makes a great DAC. The others are Playback Designs, Mytek, DAD and Naim
I will put Burmesters DAC up against any.
MarinJim
888
2
I was on Burmester's website and don't see a stand alone DAC. What is the model # and can it do >192kHz?
My apologies, one has to buy a Burmester pre or CDP to get the dac. ;) And yess 24/192
FrantzM
29
405
OT
You are not alone in this belief .. Welcome to the WBF Forum.. Long Experience with Burmester DACs starting with the 870 ... This new module would have been my DAC on the 011 Preamp ... Long Story not to be re-told
Bruce B
Apr 25, 2010
7,007
515
1,740
Snohomish, WA
www.pugetsoundstudios.com
I asked if it will do > "greater" than 192k. Lee asked if there were any DAC's that would do 352.8 and up, hence my recommendation.
There are hundreds of DACs that will do 192 now. It's the new Redbook!
ted_b
113
7
405
the soon to be released iTunes 11 will support hirez files
Steve, what do you mean by this? I get iTunes to play hirez already. Moreover, with PM and my M2tech Young protype DAC I get 24/352 and 24/384 files files (like 2L's DXD, etc) to play (using iTunes as the GUI and library manager). What is it about iTunes that will change in iTunes 11? Auto sample rate (doubt it highly as Apple does not want core audio auto-changing with multiple requests)? Thanks
Ted
MarinJim
888
2
Well, yes I quess so. But, it seems to appear you are saying all DAC sound alike (big no-no).
rblnr
May 3, 2010
2,151
292
1,670
NYC/NJ
In some casual switching back and forth, I heard no difference with Amarra in or out of the signal path from iTunes or from the Squeezebox server software (which auto-switches sampling rates btw).
An aside -- anybody heard the dcs Debussy vs the Berkeley DAC or some of its other competitors?
MarinJim
888
2
Ok. Then let me re-phrase my question. Why is 352.8 so inmportant to you? Is it the first thing you look at in a DAC? Can a 192k DAC beat a 352.8 DAC in sound? I am confused as to why 352.8 is so important.
Bruce B
Apr 25, 2010
7,007
515
1,740
Snohomish, WA
Because we do a lot of DSD mastering and the PCM sampling rate of 352.8kHz is used to edit and process DSD files in Pyramix. Plus there are now 352.8 downloads available... O'kay?
MarinJim
888
2
Well, not really. But I am happy it works for you and your situation. 'Kay?
