What's the best DAC digital interface possible?
Blizzard
Banned
Sep 30, 2015
3,049
3
Blizz - so which is better out of the Ravenna or i2s hdmi interfaces?
In terms of transports for Ravenna - is that just via standard Ethernet so any PC will do?
A well implemented Ravenna interface should be better. This is because the I2S/DSD can be sent CMOS direct over short PCB traces, as well as synchronous clocking to DAC master. Also It can be powered by ultra low noise LDO off the DAC LPS. Very similar to the SD card transport on the Mirus, but the data stream comes in via Ethernet instead of SD card.
The incoming Ethernet data stream isn't clocked yet so no jitter is introduced, and no reclocking even required. And any noise from external computers/routers can be isolated from noise using fibre.
It also allows you to use which ever computer based media application you desire. So you can take advantage of mobile app GUI's as well as PC based SDM/SRC/DSP.
Any Windows/Mac computer can be used as the transport just the same as with USB.
Audiophile Bill
4,293
4,093
675
Thanks - so when will the Ravenna boards be available? Don't Focusrite have something called Red Net - is this not the same thing?
Blizzard
Banned
Sep 30, 2015
3,049
3
Probably Q1 2016 for OEM's. There's a few other "Audio over IP" protocols. But some are proprietary, and all but Ravenna are limited to either 24/96 Or 24/192 PCM. Ravenna is a completely open standard just like USB, and it capable up to DSD 1028 over 2 channels per board, or 8 channels @ DSD 256 per board. You can also sync up to 8- 8 channel boards streaming simultaneous DSD 256 over 48 channels on a single gigabit Ethernet network, with around 1 nanosecond of channel to channel skew between boards.
Audiophile Bill
4,293
4,093
675
Very cool, thanks. So we need to add a Ravenna board to our Lampi then to enable dsd 1028 lol. We will need a fast computer to upsample our quad dsd to hexadeca dsd - that has a nice ring to it. Maybe it should be HexaDecca DSD :)
Blizzard
Banned
Sep 30, 2015
3,049
3
Not sure if there's any audible advantages above DSD 256, but if there is, Ravenna can handle it.
Bruce B
Apr 25, 2010
7,007
515
1,740
Snohomish, WA
www.pugetsoundstudios.com
I will have a new Ravenna based interface board in my possession soon I will be running through the paces. This will be the ultimate solution as an interface option. This board will render USB interfaces obsolete. So once this is ready for distribution to OEM's, Lukasz should be one of the first that is interested. Big bonus is it can easily be retrofitted into any Lampi DAC to replace the Amanero.
Check out the Merging NADAC for an example of similar implementation.
http://nadac.merging.com/networking
My Ravenna system has been stable for over 2yr. now. Also similar systems use Dante.
Blizzard
Banned
Sep 30, 2015
3,049
3
Yeah Ravenna is rock solid. Dante's good as well. Only closed, proprietary and limited to 24/192 PCM.
Blizzard
Banned
Sep 30, 2015
3,049
3
Hi guys,
I would just like to inform everyone of a surprise I've encountered with the latest gen of XMOS Xcore 200 processors. I've just heard the best audio USB yet, but I'll have to hear comparisons to find out if it's just the DAC, or the combination of DAC/interface.
Stay tuned.
bibo01
201
1
16
Hi guys,
Stay tuned.
What is it a XMOS commercial implementation that you experienced?
Blizzard
Banned
Sep 30, 2015
3,049
3
It's something I had custom made. The clocks with -114 DBc 10hz phase noise for the USB may have helped. Also the fact the DAC chip is synchronically clocked to clock #2.
RubenV.
101
14
248
for USB I used CAPS with SotM
for AES/EBU lynx from dedicated server (also Empircal Audio USB converter in the past)
For streaming the PS Audio bridge
For I2S the Pink Faun card with AV Streamer (their Sota server)
For Coax the Vanity Card in modded Oppo (with Linear PS).
All pretty decent hardware, although no doubt I could have spend more on a five figure server like aurender.
I have used differend DACs in the past, but am now using a stack of 3 x PS audio Direcstream for MCH / 2 channel.
Do you like this DAC better then the EMM Labs DAC2X?
