Avalon Saga & new Sentinel
SCAudiophile
1,186
473
1,205
Greer South Carolina (USA)
They are beautiful and member/friend strapper211 loves them...
ack
May 6, 2010
6,774
1,198
580
Boston, MA
BMCG
234
41
133
United Kingdom
ack
May 6, 2010
6,774
1,198
580
Boston, MA
I believe it's in Vietnam. In the post prior to mine, there is a link; open it and you will see more photos. I just thought it would be best to copy one here, instead of clicking all over the place
strapper211
99
23
313
Hi,
This is the second pair of Sagas I have seen with these feet.
Does anyone know what they are.
They are not Avalons.
Robert
ashandger
408
176
348
Hi,
Robert
Hi Robert, I think they might be Finite Elemente Cerabase but not 100% sure! How are your Sagas working out? Cheers
strapper211
99
23
313
Hi Ash,
They are closer to the Tesseract in technology and performance than the Isis.
They are that good.
Robert
andromedaaudio
8,497
2,842
1,400
Amsterdam holland
Reactions: infinitely baffled
ashandger
408
176
348
Hi Ash,
They are that good.
Robert
Hi Robert, wow they must be awesome! Can I ask how far is your listening seat from the speakers and also how far is the back of the speakers from the wall? They seem quite tall with tweeter right on top hence the question about listening distance. I am assuming you are still using your Lamm amps with them and Elrod cables? Many thanks, Ash
strapper211
99
23
313
Hi Ash,
I sit about 20 feet from the speakers and they are about 6 feet from the back wall,they need room to sound their best.
I am using the Lamm ML3s to drive them with the Elrod cabling .
The speakers are very efficient and easy to drive.
92 DB and at no point does the impedence drop below 4 ohms.
Robert
ashandger
408
176
348
Hi Ash,
Robert
Hi Robert, many thanks for the feedback. Happy listening. Ash
Marcus
560
554
1,155
Hi Ash,
Robert
Robert, which speakers you used before you bought Sagas? Can you comment on the difference between Saga and Isis?
south
33
12
913
Let me reopen this old thread to share my experience on listening to the Avalon Saga.
It is an extraordinary speaker, probably the best I heard. Some of my listening notes:
The bass does not go much lower than the Isis (this may be the result of the heavy accoustic treatment of the room) , but the definition is better. It has a very tight and defined bass that provides a solid foundation for the mids and highs.
The medium is extraordinary. It offers a transparent yet musical window that is mesmerizing to listen to. The way it reproduces voices is fabulous but, in particular, the way it reproduces strings is amazing. It manages to convey the dimensions and the volume of a string instrument as I had never heard.
But the tweeter is the real treat. It’s simply the best tweeter I have ever heard. I am an opera fan and this is the first time I could listen to high pitch soprano and tenor arias without sensing the “hardening” of the voices. The same applies to violins. The tweeter also has an extraordinary extension.
As usual in recent years, Avalon provides little information about the innovations the speaker brings. On the tweeter they just say it is madeof carbon fiber. I had never heard about this technology, but it seems better than the diamond used in the Isis (which is extremely good) and also than alternative solutions used by other brands , e.g. aluminium, berillium and even the newer generation silk tweeters. The midrange and tweeters are in a separated sub-chamber, that is desscribed as floating, i.e., apparently it is decoupled from both the lower enclosure and the external structure.
The Saga is also more rhythmic than the Isis. The benign impedance curve is noticeable, and it seems to be easier to amplify than previous Avalon models.
Unfortunately, as far as I know, in Europe they are only available for demo in Italy. The hi end shop that has them uses an unusual system: analogue only (TW turntables and some fabulous tapes played in Studer an Ampex), a Spectral pre and an exotic italian amplifier, the Alieno, which uses one 300B tube to produce a claimed 250 watts p/c. Cables are in aluminium. I was not at all familiar with the system. The amp sounded very well, quick and very fluid, with some of the 300B qualities but also with good control in the bass. I would have loved to hear the spewakers witha a more traditional tube pre/power.
The Sagas certainly deserve to be heard.It is a fantastic loudspeaker: hats off, Mr Patel.
