I almost bought it but at the end didn't. I have everything in their store but this album just doesn't grab me.
The latest recording from the Sound Liaison label with Carmen Gomes; ''Little Blue'' it says ';
The recording was done in 96kHz-24bit PCM. The DSD tranfers were done using a dCS DAC going into the Tascam DSD-recorder.
scroll al the way down on the page, there is the technical info;http://www.soundliaison.com/studio-masters/208-carmen-gomes-inc-little-blue
great album btw, very very well recorded and the interplay between Gomes and Tettero, the guitarist, is incredible.
scroll al the way down on the page, there is the technical info;http://www.soundliaison.com/studio-masters/208-carmen-gomes-inc-little-blueThe recording was done in 96kHz-24bit PCM. The DSD tranfers were done using a dCS DAC going into the Tascam DSD-recorder.
These quotes got me thinking, what music examples are out there, recorded in both formats?
Here is one; View attachment 21404 http://www.soundliaison.com/
I don't remember about the particular one pictured, but a few months ago all the www.sounliason.com files had level differences. .2 or .25 db at different sample rates and between PCM and DSD. That is just enough to make them audibly different for reasons of loudness alone. Not criticizing them it is a side effect of their conversion software. Just pointing it out. The recordings are very good and I don't suspect any subterfuge was intended on their part.
"Impromptu" is the only currently available title from Sound Liaison that was mastered simultaneously in PCM and DSD. Their other DSD releases are conversions from the original PCM masters.I don't remember about the particular one pictured, but a few months ago all the www.sounliason.com files had level differences. .2 or .25 db at different sample rates and between PCM and DSD. That is just enough to make them audibly different for reasons of loudness alone. Not criticizing them it is a side effect of their conversion software. Just pointing it out. The recordings are very good and I don't suspect any subterfuge was intended on their part.
I got bitten by that when I tried to do the comparison. At first DSD files converted on the fly to PCM sounded a lot better than PCM files sound liaison had provided. I lowered the gain in Roon from 6db to 4 db and all the difference vanished. Plan to do a native to PCM test but with the levels not being the same, as you say the comparison is moot.I don't remember about the particular one pictured, but a few months ago all the www.sounliason.com files had level differences. .2 or .25 db at different sample rates and between PCM and DSD. That is just enough to make them audibly different for reasons of loudness alone. Not criticizing them it is a side effect of their conversion software. Just pointing it out. The recordings are very good and I don't suspect any subterfuge was intended on their part.
Yes, good point your hearing is influenced by how fresh or tired you are.
My test was DSD converted on the fly to PCM and the ones provided as PCM by Sound Liaison. In that case, once I matched levels, I heard no difference. Prior to that the DSD sounded better.
I need to hook up my DSD DAC and test the two native formats. Been too busy/lazy with other things.
Bob Katz is describing exactly that here in this video from the AES convention;I got bitten by that when I tried to do the comparison. At first DSD files converted on the fly to PCM sounded a lot better than PCM files sound liaison had provided. I lowered the gain in Roon from 6db to 4 db and all the difference vanished. Plan to do a native to PCM test but with the levels not being the same, as you say the comparison is moot.
