That was rash of me Tim. I regretted that. I read to much into what you asked and took too little time to think it through neutrally.
Thanks, Jack.
Tim
I think you are absolutely correct, Jack. IME, there are compromises to be heard in just about all speakers and most rooms. The current 'horn' fad seems to be increasing in popularity, which I an understand from one point of view...that is that they are typically an easier load for the accompanying amp. Like Ralph says, that's a good thing. OTOH, the inherent 'cupped hands' issue and the tendency to stridency is a problem that I still think bedevils them. I have yet to hear a horn based speaker that I would want to live with for any length of time...and particularly not in a small/ish room. Like you say horses for courses, and IF I am to understand Ralph, he doesn't really believe that??
Dave C, that would seem to be the case. Most of the horns that I have heard exhibit the 'cupped hands' effect to some greater or lesser extent.
I think most horn speakers sound 'horny'.
I would not call it cupped hands by my way of thinking. More like a shouty quality. As if it shouts too loudly in some parts of the spectrum, but not all parts.
I have thought for some time with experience of DSP on loudspeakers that horns are a natural. The easiest way to control the response of a speaker is knocking down peaks. If you start with an already inefficient speaker it can become problematic. With a highly efficient horn, you have sound level to spare, so knocking down peaks to a flatter and flatter response doesn't put you in as much of a bind. Directionality of a speaker and how much it differs off axis can be trouble using DSP as well. A fairly good horn should also have a chance to control that reasonably well. So it seems a horn would be a good fit for DSP. I find most horn owners most definitely not happy with the idea of DSP. So no go for many.
Agreed, but why start off with a problem and then try and fix it? Better to start with no problem at all, IMO.
Because all speakers have problems of one sort or another which are significant. If the primary problems of a horn can be pretty well minimalized, they offer the chance to perhaps with DSP get into a rarified level of performance. Good response, good directionality, and very low distortion while having the trademark large dynamics. It isn't like other types of speakers are so good they don't benefit. That speaker hasn't been made yet to my knowledge.
One simply cannot generalise , in terms of horns, a very long horn, such as those used by the original WE's ,GOTO etc, do sound coloured by today's standards, really best to keep the horn length as short as possible, but this too has. disadvantage in terms of SPL.
Horns particular compromise is their size, they have to be BIG, if you are going to go low,and front loaded.
Keith.
So do I.Johan Hi, I think we might have the same taste,at least in terms of horns, I haven't heard anything better than Ralph's.
Keith
There can be several mechanisms for horn coloration but reflections are what cause the "cupped hands" effect. It's dependent on horn geometry and frequency, but can also be due to the perception of directional sound, which is much different when you are used to wide dispersion speakers used in live rooms. Some people think it sounds like having headphones on. It's hard to beat the immersive dimensionality and dynamics of a horn but it's not as simple to design as most other types of speakers. There are some massive threads on horn honk on diyaudio if anyone is interested...
Agreed that all speakers have some problems. However, to my ears, most horns have more problems/issues than non-horn designs. I think the basic design of the horn itself ( the shape/material/geometry of the enclosure...therefore the horn flair) is what I believe contributes the most to the problem.
To fix the issues with DSP will likely lead to a 'digital' hardness that is IMHO NOT that desirable. YMMV.
