Good Sound on a Budget A decent entry level system.
Hi-FiGuy
2,242
763
385
So for $3000.00 you can have a nice two channel set up with DAC/Tubes/Phono-Pre/Headphone Amp/Turntable with USB/Cartridge/Amplifier/Pre Amplifier and Speakers.
You can pretty much open the boxes, set this equipment on your furniture plug in and go.
This should be enough to get you hooked! :p
Peachtree Nova65SE Integrated with built in DAC and headphone amp. Great intro into tubes. $999.00
http://www.peachtreeaudio.com/nova65se-amplifier-with-dac.html
Golden Ear Triton Sevens (bottom of page) $1400.00
http://www.goldenear.com/products/triton-series
Pro-ject Debut Carbon USB $400.00
http://www.amazon.com/Pro-Ject-Debu...856&sr=8-1&keywords=pro-ject+debut+carbon+usb
Some affordable interconnects
http://www.amazon.com/s?ie=UTF8&page=1&rh=i:aps,k:audioquest cables
Johnny Vinyl
May 16, 2010
8,570
51
38
Calgary, AB
Nice system you've put together there my friend! And if one only has $2,000 they could likely buy this same system on the used market as well.
es347
35
1,620
Midwest fly over state..
Naim Muso $1500
Hi-FiGuy
2,242
763
385
How about some links for people to click on, help a brother/sister out! :D
https://www.naimaudio.com/Mu-so
You could actually hook up the pro-ject usb turntable to that device.
I cannot vouch for the sound quality, but it seems like a nice lifestyle piece.
DSkip
442
194
350
Arlington, TX
www.audiothesis.com
How about this?
Usher T-515 with stands - $840
Essence HDACC HDMI DAC - $600
Parasound Halo A23 - $995
Douglas Connection Furez IC's/XLR's - $100-150 depending on connectors.
That's around $2600 for a pretty nice rig. The T-515 is a lot of speaker for the money.
asiufy
Industry Expert/VIP Donor
Jul 8, 2011
3,711
723
1,200
San Diego, CA
almaaudio.com
In a similar-but-not-quite way to the Naim, there's the iFi Retro:
http://ifi-audio.com/products/retro/
We have one of those in the store, and it's surprisingly good, for the size and price ($2000 w/ the speakers).
It has just about everything you need: tube amp, preamp, DAC, phono stage, Bluetooth...
Another
Phelonious Ponk
8,677
23
A digitalphile solution: http://www.avihifi.co.uk/products.html#dm10
The Avi DM10 -- fully active (350 watts per mid bass driver, 75 for each tweeter), built in DAC (Wofson 24/192) and simple remote-controlled pre (volume/inputs, separate volume and crossover controls for the optional sub). These are two generations beyond the 9.1s I have, which are incredibly clear and powerful, and I know what they've been working on - even greater clarity. Probably not for lovers of analog's colorations, but not strident or harsh either. Imaging is amazing, even now that I no longer have them in a near-field setup. 1500 pounds, which at the current exchange rate is $2313.61. The sub will take you up another $1500. Just add source and stir.
Tim
amirm
Banned
Apr 2, 2010
15,813
38
Seattle, WA
Are there any alternatives to this? I bought my son one of their DACs and unfortunately the internal resampler (?) clips on some of his music. So he had to ditch it and get a different system.
Also, have others had good experience with their tube? I thought it just added bad distortion.
BTW, I am a fan of the company and products. Just haven't had good experiences with the two points above.
DaveyF
6,129
181
458
La Jolla, Calif USA
I have heard some very good things about the new Marantz HD DAC 1. Priced at $799-. Includes a headphone amp and Double DSD! Also features a USB connection....just add the computer/ headphones and off you go.
amirm
Banned
Apr 2, 2010
15,813
38
Seattle, WA
It certainly looks nice:
amirm
Banned
Apr 2, 2010
15,813
38
Seattle, WA
Japanese companies are starting to wake up to this market with Panasonic/Technics coming into the market.
