What is the best Digital Interface for High End Audio? USB? S/PDIF? Does it Matter?
caesar
775
1,698
What is the best Digital Interface? USB or S/PDIF?
Or does it really matter whether it's USB or S/PDIF, assuming you are using a quality, high end DAC?
Audioseduction
178
8
925
FLORIDA
From my personal experience it does. I prefer ST Optical Glass Fiber myself.
Thetiminator
86
19
238
I agree that USB is far from the best interface. IME I find a USB/SPDIF converter in the chain always improves the sound.
My custom made server outputs via fibre optic (or fiber seeing that I'm speaking to the U.S) as I was assured it was the best way to go. I don't have any experience of AT&T Glass but I'd imagine it's very similar to my set up. In order from my experience:
Fibre optic
AES/EBU
Digital coax
USB
Toslink
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
I don't think there is a generically valid single answer to this quesiton. It is systems dependent. Based on my experience, #1 would be ethernet streaming, #2 USB. I will sound take possession of a server that has I2S card, and also have an AES/EBU source. Whatever I end up preferring may not work best in other systems.
Fitzcaraldo215
394
2
Wrong question. The right question concerns the DAC. Choose the DAC that you like and it will likely determine which way it can connect. Most only have one way. But, the DAC is much more important than the computer, O/S, cables or anything else.
I agree it is hard to generalize, but I prefer asynchronous USB - regular USB is almost dead these days in the marketplace, but the same USB cables are used in either case. Properly implemented, asynch USB has zero jitter.
Bruce B
Apr 25, 2010
7,007
515
1,740
Snohomish, WA
www.pugetsoundstudios.com
The professionals that record and master your albums use:
ST-optical
AES/EBU
MADI
Ethernet
jeromelang
439
66
935
My experiences with the TSDX and DAC2X showed me the ST Optical cables are (highly) directional, different lengths do matter (1m vs 4m lengths), and that there could even be sonic differences between 2 cables of the same brand, and the same lengths.
Could this be due to the varying air gap distances between connecting joints?
Who knows?
But I'm not very keen on applying opti-gel between the connecting joints.
Bruce B
Apr 25, 2010
7,007
515
1,740
Snohomish, WA
Who knows?
My experience has been different. I've used 1m and up to 100' with no detectable difference.
Phelonious Ponk
8,677
23
Do you find them to be directional? That one is a bit mysterious...
Tim
DonH50
Jun 22, 2010
3,952
312
1,670
Monument, CO
It makes sense if the electrical side is messed up inside one of the components. If length is also a factor at such low lengths I suspect the receiver in one of the components is bad. Or just dirty...
caesar
775
1,698
Not really. The new CA architecture that has evolved is more complex, with decoupled tasks and dedicated boxes, such as streamers, servers, dacs, etc., which frequently outperform the laptop computer most use today.
And it’s more than just the dac you like. What if you find a better dac? What if other components in your system change breaking up synergy? What if you start to prefer a different flavor in your dac? Or what if there is a technological advance you want to take advantage of, and need to swap out some components in this new CA architecture? So depending on the digital components you choose, you don't want to get locked in.
Audioseduction
178
8
925
FLORIDA
Tim
No they are not. When I was in IT and installing fiber their was no such thing as directional. That's very funny!
jeromelang
439
66
935
I didn't hear a difference directionally either. I am using the garden variety orange cables you get from Fry's.
I am using the stock orange colour cables, provided by emm lab.
I also bought 2 pairs of 4 meters from that link you provided previously.
All 5 pieces are directional. Meaning they sound better connected only in one direction, and not the other.
The changes in soundstage height, width, and depth, plus soundstage perspective is unmistakeably audible.
All the 4 meter cables sounded "slow" compared to the stock, and imaging tend to be effusive and vague.
A fellow user of the TSDX / DAC2X brought over his original stock cable to my place and his cable also proved to be directional as well. (We subsequently found that he had been using it in the wrong direction...)
Both our stock cables sound slightly different, though the degree of difference is not as great as comparing between 1m vs the 4m lengths.
We were both contemplating - what if we apply the opti gel?
Will it even out the differences?
Anybody who has ever use any opti gel gel to maintain consistent refraction index please do share your experiences.
And also, does the gel ever get dried up?
If so, how to clean out the dried out jelly?????
Fitzcaraldo215
394
2
Not following you. There is always something better, but you always need a DAC. If your chosen DAC locks you into, say, USB, then so be it, temporarily. If you change your mind and later select a coax input DAC, it is not the end of the world. Get new cables and a coax output card to support that. I do not see why you are permanently locking yourself in. The advantage of computer based playback is flexibility and modifiability. You are locking yourself in just as much if you start with a coax only DAC. And, it might not be worthwhile to limit yourself to a DAC that can do both, either sound quality or cost-wise.
But, if maximum flexibility is what you want, then USB has a clear edge. My take is that there are many more USB DACS, especially Asynch USB, than coax or other interfaces, especially among newer ones.
And, I still maintain that the DAC has the greatest impact on sound. It alone converts digital data transfers to analog signal, each DAC having its own sonic signature or lack thereof. And, better DACS are more insulated from noise coming from the computer or the cables, hubs, etc. that might adversely influence the analog output. Also, there is much more available in add-on devices to shield the DAC from noise via USB than coax, if necessary, including galvanic isolation if you need it. I do not see that in coax.
DonH50
Jun 22, 2010
3,952
312
1,670
Monument, CO
I'd love to see a BER test showing differences in directionality. Unless there is something wrong that cannot happen. That said I am not familiar with ECC on these links.
I would not use gel on TOSLINK but feel free to see if it further improves the sound and/or reduces differences among cables and directionality. And yes it can dry out. It will flake off and you have to use some sort of cleaning agent and potentially repolish the ends.
jeromelang
439
66
935
In an optical connector, where the 2 fiber are connected butt to butt, there will be a small air gap between the butt ends of the fibers.
That air gap will have a refractive index different from the fibers, and these variations in refractive index at the optical connectors will induce some reflection of the light being conducted, which in turn will give rise to increased jitter upon reception.
I believe this is what causing me to hear very audible differences whenever the directionality is changed, because what I had done probably was changing the amount of air gap at either end...!?!?!
The opti gel that I was talking about is more commonly called an 'index matching fluid' in the fiber optics industry.
What a good index matching fluid does is to fill that air gap with a substance having a refractive index closer to that of the optical fiber. Such fluids are commonly used in the telecom industry. Just do a google search.
Looks like the ST Optical interface is not such a "perfect" digital interface after all......
joaovieira
391
273
970
Brazil
Agree. Perfect for me.
caesar
775
1,698
It's the other components in the architecture that can lock you in, such as the music server, which may impact the ability to access your entire music library.
