Cartridge Recommendation
kleinbje
181
24
923
CT
Hi All,
I am looking for a next level Cart for my Classic 3 with 3D arm. I have a Lyra Kleos Sl into a Davinci MC4 SUT to a Lamm Lp2. I listen to rock almost exclusively, with some Jazz and softer stuff like Cat Stevens/Otis Redding thrown in. I have thought about everything from a Zyx Universe to Atlas/Etna, Proteus, DV xv1s(?), koetsu, and frankly I'm overwhelmed given you can't really audition, and in my own experience there are so many variables as to how a cart sounds in a system. I am looking new and used and would like to keep it under 5K. Cheaper the better though. All your input experience is welcome, specific setups and records that really make your recommendation sing, are very helpful.
Thanks
Jeff
JackD201
1,429
1,820
Manila, Philippines
Hi Jeff,
What is the step up ratio of the MC4?
Best
Jack
ddk
6,261
4,043
995
Utah
Hi All,
Thanks
Jeff
Hi Jeff,
After nearly 35 years experiencing many different cartridges I still find Ortofons among the most musical and my overall favorite brand. Their SPU-N with either the ST-80 SUT or direct into your Lam will be a great match to your system and musical tastes. But if like many here you're compelled to spend more you go up the line to a Cadenza Red or the wonderful MC Windfeld. You won't need the MC4 with these cartridges.
david
BobM
169
9
150
65
Long Island, NY
What don;t you like about the Kleos, or what areas do you want to improve on?
Personally I find my Kleos great on rock and roll. Very punchy and dynamic. Maybe you just need to tweak the setup?
kleinbje
181
24
923
CT
Bob,
I love my Kleos I just want more! Deeper bass, more intense dynamics, bigger soundstage etc. I loved my Chinook then got the Lamm, it was like I was hearing another level of the music. I was looking for a similar step up with a new cart.
JackD201
1,429
1,820
Manila, Philippines
jfrech
2,157
752
1,160
Austin
Sunnyboy1956
240
2
123
67
New Delhi, India
Altanpsx
75
2
6
For sure lyra atlas and etna are very good cartridges, but i suggest you to listen transfiguration proteus, imho for a better price, you may get better results then lyra's.
kleinbje
181
24
923
CT
Given that you have an atlas and LPS can you offer any particulars regarding them to the proteus? Some nice LPs just came up used as well.
