Yes I think below the AR amps you might not get as much benefit. Mind you shun mook does not have a float everything on our product philosophy like stillpoints do.
The resonator affect was certainly evident on the stereo amplifiers, however Giants did not prove an exponential improvment over Ultra's in that application, hence my purchase. Worst case scenario I will use them as Steroid'd M'pingo Discs
I'm going to be setting up my system from scratch in my new dedicated space after nearly 12 months of no music 🙄, and one of my first fascinating a-b's after a period of settling in, will be how my set of Giants will change things under either linestage or cdp...or maybe even my 150lb 8kVA balanced power transformer
Hmmmm, in the same vein as my amplification experimentation, the efficacy of your Giants may be somewhat wasted on your BPT as compared to the effect that they will lend to your source or line stage components, I would suggest that a set of ultra's or even super's may prove to be an excellent compromise in that application.
When back in London, I had them under my BPT and they were pretty effective
Even under my Entreq Silver Tellus there were marked effects
Harlequin, why are you skeptical re Giants under my BPT? It is 18" X 16" and weighs in excess of 150lb, surely ideal for Giants?
Bookmarks
