which speaker for gryphon diablo
maslak34
Question for Diablo owners.
I recently bought gryphon Diablo
Rest of the system is gryphon Mikado (not signature)
Af2 turntable (upcoming) techdas tdci cartridge(upcoming) phasemation phono stage (upcoming)
Cables all acoustic revive triple c
Current speaker verity audio Parsifal.
Potential speakers to try
B&w 800 n
Gryphon pantheon
Yg acoustics hailey
Open to hear your suggestion
My room size is big. 8meters wide.. 10 meters deep and 3meters high
Reactions: bmarq
LL21
14,411
2,509
1,448
Fantastic room and nice electronics. I have spent a little time with B&W, YG Anat Ref IIs, but not the others. My personal favorites are the Rockports and the Wilsons...you can easily drive either with your electronics. (The one exception is the Rockport Arrakis which is ideally driven by at least 2 sets of Gryphon monos. Most setups i see use 3 sets of Gryphon monos.).
I have heard good things about the Pantheon...in a room as big as yours, you could comfortably fit a big Alexandria or Altair + dual subs.
maslak34
I have had several experiences with high end speakers. Yg anats, magicos, to name a few
My biggest concern is b&w requires a lot of power( Diablo has but is it enough?)
Pantheon I listened in Munich 2014 and also at the local dealer with antileon sigs pandorra and kalliope
Yg Hailey not yet heard
Pantheon is great but whether Diablo can drive it is a question mark other no contest.
Wilsons always have been not my fav speakers
Rockports though are real contenders...
Time to do more research on rockports
LL21
14,411
2,509
1,448
My own personal viewpoint is that your Diablos probably can drive the B&Ws. Yes, a big fan of Rockports and the natural synergy between gryphon and Rockport is not only well known, as you no doubt know, Andy Payor himself has Gryphon electronics throughout his studios in Maine. He also uses VTL and used to use CJ as well...but Gryphon is a well documented piece of his studio system. As are Transparent Audio cables which are used inside his speakers.
Good luck...you've got a great ride ahead of you! Enjoy it.
Luiz Felipe
67
1
Rio de Janeiro - Brazil
Don't Concern, Diablo is more than you need for BW 800N requests, but this speaker is very far of Pantheon Speakers. They are in absolutely different levels, so I can't figure about compare both. Pantheon will be very better in absolutely all aspects. If you can, go for pantheon.
In my opinion, replace a Verity parsinfal to a bw 800N should be a downgrade, not an upgrade. Several speakers you inform have very different price levels, if you inform where you live and what budget you have for it should be easier to help you.
Pantheon reach 25hz. For your big room it will fit perfectly. I have no experience with YG. Just listened in Shows, not with Diablo.
david.m
11
1
133
Sydney, Australia
IMO B&W's are not up with the rest of your system. I owned 802D's for several years and spent several hours with 801Diamonds before I went with the Avior's, the Rockport's are most certainly at another level in every respect. Unfortunately I've no experience with the other speakers mentioned.
Down Under
191
42
333
Would anyone who has listened to the Pantheon be prepared to make a few more detailed comments please.
maslak34
B&w 800 n
Gryphon pantheon
Yg acoustics hailey
Any experience with verity sarastro and Diablo? Anyone
