4 CH Line stage makes its debut
doshiaudio
75
7
238
Virginia
www.doshiaudio.com
Doshi Audio has built and delivered a 4 channel line stage. The unit was auditioned using a 4 channel down mix of SACD and custom 4 channel recordings and the results were stunning. There is so much spatial information that even the best systems simply do not deliver. For the lucky few that can afford it and have the space to do it, its a must audition. IMG_0854 (2).jpg
still-one
1,633
150
1,220
Milford, Michigan
Nick
So that is the unit you were describing at the recent Paragon event. Pretty nice.
Kal Rubinson
2,362
705
1,700
NYC
www.stereophile.com
Only 4 channels? Why not 6 so that there would be no need for downsampling and PCM conversion? Quad?
Bruce B
Apr 25, 2010
7,007
515
1,740
Snohomish, WA
www.pugetsoundstudios.com
It's a custom build Kal. It is what the customer wanted. If you want a 6-channel line stage, Nick can build you one!
Kal Rubinson
2,362
705
1,700
NYC
www.stereophile.com
I missed that in the original post and assumed it was a "regular" product.
This unit was a response to a specific requirement. I would be happy to consider requests for additional channels as well as power amplifiers for the additional channels.:)
Thanks for the offer.
bonzo75
22,617
13,635
2,710
London
Hi so this is a multichannel TUBE amp, or SS?
Also, in the Mch, does it have DSP, or pure analog, and do things get downsampled to PCM?
Kal Rubinson
2,362
705
1,700
NYC
www.stereophile.com
I see the tubes in the pic and it has only analog in/outs, so I doubt it is anything but pure analog.
Audiotom
5
1
81
The power response of the low end generated by 4 channels has to be heard to be believed. it also seems like higher SPL's are tolerated better by our ears when the location cues are 360
How is this being implemented? 4 channel surround? A separate powered sub off the bluray source?
Kal Rubinson
2,362
705
1,700
NYC
www.stereophile.com
Apparently, it has 4 straight-through analog channels, each of which can be anything. There seems not to be any options for a specialized sub channel, down-mixing, bass management or anything but level/phase controls. IMHO, that is as it should be.
doshiaudio
75
7
238
Virginia
www.doshiaudio.com
That's correct - this unit was developed for a specific customer (now 2) who has a large library of multichannel live recordings. My personal opinion is that 4 full range channels are sufficient to create an immersive sound field with hall cues available that transcend the 2 channel experience.
still-one
1,633
150
1,220
Milford, Michigan
I attended Nick's recent event at Paragon and was impressed by the multichannel presentation. If there was multi-channel content in the genres I care about I would be interested.
Kal Rubinson
2,362
705
1,700
NYC
www.stereophile.com
One can argue about whether 4channels are sufficient or if more are required. However, you cannot argue with the fact that the majority of available multichannel recordings are either 5.1 or 5.0 and to play them on a 4.0 system requires that one either eliminate the center channel or split it between the L/R. Both of those corruptive. I'll stick with my 5.1 systems which can also play 4.0 with aplomb.
