Ultra 6 being released
KeithR
5,156
2,820
1,898
Encino, CA
$900 for a point? He should have just gone for a cool $1k. Wow.
Has anyone compared with Wave Kinetics which are $800/4?
Thanks
LL21
14,423
2,516
1,448
DEV
547
6
Ya I knew they were coming - happy I didn't load up on 5's and only have them under my speakers.
You will never be done :D:D
LL21
14,423
2,516
1,448
just out of curiosity, i probably will try them next time i get a chance...but i am so happy with where we are, i have moved on to tackle a much bigger source of vibration. We shall see.
PeterA
12,645
10,896
3,515
USA
Thanks
I think they are a cool $1K if you include the footer/base or hat?. IOW, $8K for a pair of speakers.
If adding them to a Sasha (or S3) makes it sound like an Alexia (or S5), it may be worth it ;) Seriously, these may be more appropriate for a $80K+ speaker (10% of cost).
At this price one is close to Vibraplane or Minus K territory if considering three of these under a piece of electronics or DAC.
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
No doubt someone will find a way to install a mid size sedan worth of these in his system for a truly transformative sonic experience.
dmnc02
326
1
PA, USA
These were announced at CES last year. Compared to the Ultra 5, they have an additional technology pocket on the bottom side (bringing the total number of pockets to 6). They need to be screwed in or used with the optional bases.
Bruce B
Apr 25, 2010
7,007
515
1,740
Snohomish, WA
www.pugetsoundstudios.com
Thanks
I tried the Wave Kinetics under both speaker and amps and didn't hear a difference. The Stillpoints are the real deal!!
rockitman
7,097
414
1,210
Northern NY
They don't look much different than the 5's. Looks like the same amount of technology pockets as well. Will these replace the 5's or be an addition to the current line of products?
I'm not replacing my 5's but if I need more I will try the 6's...most likely when I pull the trigger on the pass xs pre.
rbbert
3,820
239
1,000
Reno, NV
Look at the pictures and read the description more closely ;)
