Long run XLR interconnect
Bruce B
Apr 25, 2010
7,007
515
1,740
Snohomish, WA
www.pugetsoundstudios.com
I have used a couple of different sets of 20' and 30' Mogami cables and enjoy them. Hard to go wrong for the money. You can always use them as a reference if you want to compare something else later.
I have used Redco Audio to do custom lengths and terminations with good results.
http://www.redco.com/Custom-Cable.html
Redco did all my custom DB25 cables here in the studio. I have a few 100 footers between the rooms. Excellent service and top notch quality!
number95
384
7
250
Thanks you all for your help
Let me make it simpler, if you had to choose a 30' balanced cable? what would you do? (i know some of you already answered, thanks)
arthurs,
No more KR, i am moving away from tubes, the Einstein is the only tube component i got left and for some reason i can't let it go.
(i do have a new room and a new system, i'll update my system thread soon)
I have a 27" balanced cable between preamp and power amps which is Transparent Ref MM (mm2 version) and quite pleased with it.
ACHiPo
519
309
310
Pleasanton, CA
Amazing.
I received those few days back, i hooked them up, amazing results.
I did a quick test with my two other short XLR cables (and much more expensive) and couldn't hear any difference, of course i would need more time to compare but overall i was pleasantly surprised
Thanks!
I received a pair of Mogami Gold Studio 25' interconnects last Thursday and have had them playing in the system since Thursday night. I'm very impressed so far. And yes, cable quality does matter for balanced XLRs, as I can definitely hear a difference between the cheapo MonoPrice XLRs and the Mogamis. I can't however, hear much difference between the JenaLabs Symphony cable (~$1500) and the Mogami, but I haven't done a close comparison.
ACHiPo
519
309
310
Pleasanton, CA
IMO, at 30' the Mogami Gold Stage microphone cable might outperform many high-end audiophile cables. In long lengths, I find it very much more transparent and intrude less on the signal.
The Mogami AES/EBU cable I prefer as a balanced interconnect in short runs - less than 2m. I also like the Quad Neglex, but it has a little higher capacitance and a little lower inductance and I use it for greater than 2m and less than 5m.
With long XLR cables >4m, I haven't found a commercial high-end cable I like as much as the two Mogami. Disclaimer - I haven't tried them all, only the ones that other cable manufacturers have loaned me to try.
What is the audible difference between the digital and mic cables? What about the difference between the stage and studio cables?
Speedskater
941
15
368
Cleveland Ohio
Digital cables are optimized to have the correct Radio Frequency Characteristic Impedance.
Mic cables are optimized for mechanical factors like robustness and flexibility.
'stage and studio cables' seems to be more about use than cable factors.
All good balanced interconnect cable should have low Shield Current Induced Noise (SCIN) which requires big expensive machines to manufacture the bulk cable.
Good cables don't have a sound it's the noise and interference that the poor cables pick-up that has a sound.
ACHiPo
519
309
310
Pleasanton, CA
Thanks, that's what I figured, but the capacitance and inductance are a little different between the digital, stage, and studio cables. I'm pretty happy with the studio 25', so much so that I ordered two pairs of 3' for interconnects between my CDP and phono stage and preamp.
HughP3
416
652
325
63
Firing the old thread back up. I need 30Ft of XLR but NOT interested in $1000 p/f pricing. Any ideas here in 2020? thanks!
ACHiPo
519
309
310
Pleasanton, CA
I ended up going with Darwin Cable's top of the line Truth XLR cables. I can't remember what I spent, but I know it was a lot more than Mogami (and worth it), but I think it was in the $3k range for 21'.
Darwin Cables
HughP3
416
652
325
63
Thanks!
Darwin Cables
DonH50
Jun 22, 2010
3,952
312
1,670
Monument, CO
ProCo, Mogami, Canare -- all available at Sweeter Sound (www.sweetwater.com) or any pro audio store. ProCo is good and I've used a bunch in pro and consumer installations. Mogami is great as well but more money. Canare is between them in price (last I checked, year or two ago), but is available in a star-quad configuration for better noise rejection (from external noise) if you need that. Mogami and Canare is available is various styles that have varying degrees of flexibility and shielding.
HTH - Don
HughP3
416
652
325
63
Thanks Don. I was also looking at AudioQuest Earth series XLR, maybe Wind but the price jump is significant even with the typical discount.
asiufy
Industry Expert/VIP Donor
Jul 8, 2011
3,711
723
1,200
San Diego, CA
almaaudio.com
Hugh,
Analysis Plus makes great cables for that usage. Their two entry-level tiers:
Chocolate Oval-In at 10 meters = $609
Copper Oval-In at 10 meters = $1755
HTH,
Alex
HughP3
416
652
325
63
Hugh,
HTH,
Alex
Alex I have not heard of these. Will research tonight. So many....
DonH50
Jun 22, 2010
3,952
312
1,670
Monument, CO
Oops, if you are looking for audiophile cables I can't help, sorry. The cables I use have been used in a myriad of recording studios, live sound systems, and such but are the types of things pro audio guys use, and some more subjective audiophile types (I am an EE), not your typical audiophile brands. I'm cheap and figure if they are good enough to work in live venues and recording studios they'll work for me at home... I used to have bags full but quit doing live sound a number of years ago and got rid of most of the cables (and mics, etc.)
Reactions: HughP3
Kal Rubinson
2,362
706
1,700
NYC
www.stereophile.com
I have been using 10m AudioQuest Earth XLRs for my front speakers for years and they are excellent. That is not to say that they are superior to other alternatives. My only criticism is that the connectors are of soft metal (intentionally, according to AQ) and do not latch. See: https://www.stereophile.com/content/music-round-74
Reactions: HughP3
4,702
In the audiophile area, at such length perhaps you should consider the pF/m (capacity per length unit) , not just the source. What is the piece of equipment driving the cable?
HughP3
416
652
325
63
Thanks all for the responses, much appreciated!
Microstrip, a Gryphon Pandora pre will be the driver. I can rebuild engines but electrical stuff does not compute. Anyhow I just heard from a dealer that he has a found a 30 foot demo pair of Cardas Clear for a very very good deal. I think I will go with those.
HughP3
416
652
325
63
DonH50
Jun 22, 2010
3,952
312
1,670
Monument, CO
Unless they are really messed up, or the source impedance really high, the distributed capacitance in 30' of XLR cable won't matter... Star quad does run higher, natch.
Bruce B
Apr 25, 2010
7,007
515
1,740
Snohomish, WA
The longest audiophile cable I've used are the JPS Labs Aluminata at 9m. I love the shielding ... especially for studio use.
