I just received my Artisan Fidelity SP10MK3 NGS TT and though I am early into the setup and fine tuning stages, I am getting a good appreciation for the capabilities of this turntable.
One thing for certain is every tweak and bit of tuning yields a change - this table communicates in a very direct and transparent way. I have some further optimizations to do (like getting VTA in the right range) but as it is now, the sound is very dynamic, extended in lower and upper registers (more on the bass later), and very transparent and resolving.
In the Mono & Stereo review of this TT, he mentions a slight deficit in the high frequency extension but I find it more extended up top than my previous setup. Perhaps this has to do with tonearm & cart interactions with the TT? The bass is prodigious as described in the same review.
To provide some background, I am coming from a Clearaudio Innovation Wood TT and am using the same tonearm and cart combo - FR66s with Koetsu Blue Lace Platinum (i.e. same components used in both setups). My phono, preamp, and amps are all Ypsilon. I am using UNI-DIN geometry and a titanium headshell with my FR66s.
Here are some photos of the TT during and after the setup process - the other tonearm is an FR64s with a Koetsu Urushi Black on rotation.
The massive SP10MK3 motor shown here:
The platter installed (without the copper mat mounted yet):
And the final assembly:
The fit and finish on this Artisan Fidelity TT are superb and the plinth is quite a feat of engineering at almost 250lbs (complete assembly)!
Cheers, Joe
