Tools you must have: an almost perfect stud finder!
amirm
Banned
Apr 2, 2010
15,813
38
Seattle, WA
It is amazing how long we have lived with lousy, hard to use and very unreliable "stud finder" to find the structure members behind drywall/plaster to screw something into. Often I just use my knuckle and tap on the surface as that is more reliable than these junk finders.
Enter the Franklin Sensors ProSensor 710 Precision Stud Finder.
As the picture shows, this unit has a row of sensors instead of one. So it is able to instantly show one or more studs including their width! You don't need to calibrate it by sliding it from a place that has no stud.
I read about this when it came out but did not buy one until last week. As soon as I tried it, it put a smile on my face :). Price is US $50.
Highly recommended.
Matt193
193
Wisconsin
Thanks for posting this, Amir! I saw someone use this one a home improvement show a few weeks ago but they didn't mention who made it and there was nothing in the credits about it. I am definitely going to check it out.
GaryProtein
2,542
31
385
NY
I just ordered it. I'll report back in a few days!
rblnr
May 3, 2010
2,151
292
1,670
NYC/NJ
Was just about to drill some holes in my garage ceiling to secure a pull up bar. Was dreading having to rely on my $15 stud finder and all its uncertainty. This looks great, the multiple LEDs showing both width of and between studs is a great idea.
Nice to see common items like to rethought and (hopefully) improved.
JackD201
1,429
1,820
Manila, Philippines
You can still do pull ups? I'm jealous :D
treitz3
Super Moderator
Staff member
Dec 25, 2011
5,480
1,007
1,320
Hello, Amir. Normally I would rush out and get a tool like this but this time, I will not. I have already thrown out an estimated 4-5 bills on this exact type of tool and the unreliable one I hesitantly use has the multi-LED technology that should (in theory) let you mark both outside dimensions of the stud. At times, it works great finding and being able to mark the stud. Other times, it would have been easier to simply remove the sheet rock, mark where the studs are and patch back up. I have rarely been so frustrated with a tool(s) that at times, never seems to work. In fact, the old school $2.00 magnetic stud finder is more reliable than any of these type of tools I have used to date.
The most reliable out of all of the unreliable that I have found is http://www.amazon.com/Zircon-MultiScanner-Pro-SL-Multifunction/dp/B000XH56PO/ref=pd_sxp_grid_pt_2_2 but it's the same ol', same ol'. Half the time, it works great and the other half of the time you just want to skip it across a lake because it is a complete waste of time. Keep in mind, I have always used these tools on a very frequent basis in remodel, addition or restoration projects so I'm sure you can imagine the environment surrounding there use. In other words, I don't use them to hang a picture in the middle of a wall. I put them through the test, about every one you could possibly imagine.
Forgive my skepticism. I will cautiously read more about this tool and look forward to any observations the forum members who purchased this unit have to offer but I have to be honest. With these things, I will hope for the best and expect the worst. History with these types of tools and myself has unfortunately not been a good one.
Tom
rblnr
May 3, 2010
2,151
292
1,670
NYC/NJ
amirm
Banned
Apr 2, 2010
15,813
38
Seattle, WA
Tom
I said it was almost perfect Tom :). That said, my interest initially came from reading this thread: http://www.remotecentral.com/cgi-bin/mboard/rc-custom/thread.cgi?29826,3. That forum is dedicated to Custom AV folks so the application is real and tools must work. My team bought a few and they are all happy with them as far as I know. So while it won't work in every instance, I am surprised how much better it is than all the rest.
Here are the reviews on Amazon: http://www.amazon.com/Franklin-Sensors-ProSensor-710-Precision/dp/B0064EICKG?tag=5336121792-20. 4.5 stars and 782 reviews!
By the way, the other one that gets good reviews is the one with magnets in it that find the drywall screws.
treitz3
Super Moderator
Staff member
Dec 25, 2011
5,480
1,007
1,320
Don't get me wrong, I am entertaining the thought and I thank you for the recommendation.
I don't know what it has on the back of the unit but you may find this to be a useful tip. On all of mine, I installed the female part only of Heavy Duty Velcro tape to the back. This accomplishes two things. One, it provides a smooth sliding feature when sliding it across the walls which I have found to improve accuracy and two, it provides a non-marring surface for the finder to slide across the wall with. That makes it perfect for freshly painted walls, specialty applications and surfaces you can not damage in any way. Just note that it will not work too well with sand texture.
Tom
zztop7
750
3
Edmonds, WA
Or -rip off the thin brown cardboard on the back of a legal pad & hold that against the wall when sliding the detector.
zz.
Nyima
2
Does this stud finder have any audio feedback? For example, does it beep or make any other noise when you're over a stud?
I'm asking because that sort of audio feedback would allow this to be used by blind and low vision individuals.
Thanks!
GaryProtein
2,542
31
385
NY
Thanks!
SERIOUSLY, to be used by the blind????
People with severe vision impairment can do many things, but construction projects are best left to people who can see what they are doing. The blind??? They should definitely leave any type of construction project to someone else.
Folsom
6,032
1,503
550
Eastern WA
It does not make sound. It is however indeed the best stud finder ever.
Gary have you never heard of the classes Construction and Power-Tools, Skills for the Seeing Impaired? They're part of a government program.
es347
35
1,620
Midwest fly over state..
..I wonder what happens when Tom Selleck uses one of these things. Seems like it would go off in his hand.. :p
GaryProtein
2,542
31
385
NY
For the sight impaired, fine, but sight impaired has limits.
The BLIND doing construction of any type. . . I don't think so. How could you trust its quality?
Folsom
6,032
1,503
550
Eastern WA
Wow... I can't believe I just got you! hahahaha
How many seeing impaired people (including legally blind) really want to use nail guns, tablesaws, and such?
Don Hills
366
1
323
Wellington, New Zealand
Or -rip off the thin brown cardboard on the back of a legal pad & hold that against the wall when sliding the detector. ...
The velcro generally works well (my cheap Stanley auto-calibrating one came with the velcro installed), but it collects grit over time. The cardboard is cheap insurance.
I guess I'm lucky, I've not had a problem finding studs with it. My house's walls aren't the easiest to scan, they're sheetrock over 12mm match lining (1/2" x 8" boards). I don't know how it would perform on lath-and-plaster though.
My dad's stud finder was a hammer...
Ronm1
1,745
4
wtOMitMutb NH
And a trustworthy pair of ears
GaryProtein
2,542
31
385
NY
Well, I was being polite because I didn't want to make it seem like I thought the poster before me was an idiot with his or her first post. Besides, the government has numerous stupid programs.
