Hockey pucks and felt pads!
Johnny Vinyl
May 16, 2010
8,570
51
38
Calgary, AB
I've been having some problems with my TT ever since I moved it into my new 2CH room and mounted on a Sonora five-shelf audio rack. The rack itself is great and I love it, but with the TT placed on it I noticed an increase in rumble. I didn't recognize that having all of my components on the same rack as my TT would present me with this conundrum, but it did.
Not having a lot of disposible dollars to rectify this situation with some degree of certainty, I decided to look at other options and entertain the idea of doing something with "out of the box" thinking. I had read of several people using Hockey Pucks as Isolation/Vibration devices, and I thought, being Canadian, this may be right up my alley! LOL! So I got to thinking. What if I used Hockey pucks and then applied some kind of vibration control on both sides to help absorb/minimize sound waves travelling up the audio rack. It didn't take long to figure out that felt pads used for the bottom of chairs might do the trick, so I started looking . Lo and behold I find that they make these pads in exactly the same size as hockey pucks (3" in diameter). So off I go to that most Canadian of all Candian DIY stores...Canadian Tire!
So now I'm at home with 4 Hockey Pucks and 2 packages of felt pads (8 pads in total) and wondering what to do next. Having the hockey pucks placed underneath the TT and then leveling everything wouldn't work out...I needed another leveling surface. AH! I know! The butcher block that has been sitting there doing nothing would work. It's 14"x19"x1.75" ...freagin' perfect!
I next got to work assembling the felt (sticky back) pads to the hocky pucks and removed the TT from the top shelf. I measured and leveled until I was satisfied and placed the TT on top of it. I measured and leveled again and my small project was complete. With the butcher block addition I basically have a dual-plinth TT!
So , did it work? Has it made a difference? YES! Absolutely and categorically YES!
The bass it tighter, the rumble has disappeared, the mid-range seems clearer and much more succinct, and the upper frequencies don't suffer from any type of ringing at all.
Here are a few pics of what I did...not bad for a $12 investment, eh?
John
Johnny Vinyl
May 16, 2010
8,570
51
38
Calgary, AB
And just for the hell of it...here is a video
That was the MOFI "Sinatra At The Sands" LP.
John
Johnny Vinyl
May 16, 2010
8,570
51
38
Calgary, AB
So between yesterday afternoon and now I must have listened for at least 4 hours, if not 5/6. I'm here to tell you that this small tweak made an amazing difference. I think that applying the felt pads to both the bottom and the top of the hockey pucks was key. I am so convinced this method works that I'm going to apply it to my AVR for further isolation/vibration control.
John
Johnny Vinyl
May 16, 2010
8,570
51
38
Calgary, AB
I have been using hockey pucks under my monoblocks for some time now and have several more that I intend to use beneath my Rega P3. They are a great poor man's isolation "device"...just watch your front teeth! :D
Just the pucks or the felt padding as well? Poor man, shmoor man...if it works who the heck cares.
John
Gregadd
1,790
1,850
Metro DC
JackD201
1,429
1,820
Manila, Philippines
It even looks good! Great work John!
Johnny Vinyl
May 16, 2010
8,570
51
38
Calgary, AB
Thanks Jack! I like the look of it as well!
I went a step further and bought another set to use underneath my AVR. Since it is the source that regrettably allows the sound to travel along the audio rack why not isolate it and try to reduce the vibration. I'm hoping to hear a further tightening up of the sound, although I suspect it may not be as dramatic. I'll let you know what I think of the combination after some listening in the next few days. Here's a pic of the AVR and the incorporated Pucks.
John
Gregadd
1,790
1,850
Metro DC
Did you place a level on top? You know some people like everything plum and square.:eek:
John
JackD201
1,429
1,820
Manila, Philippines
John,
You might want to try them between chassis and rack aside from feet and rack. You might be surprised :)
Jack
Johnny Vinyl
May 16, 2010
8,570
51
38
Calgary, AB
Trust me...everything is plumb-bobbed to the hilt! LOL!
John,
Jack
I actually thought about that as well Jack. Gonna have a trial run with the way it is now and then try your recommendation.
John
soundofvoid
Apr 22, 2010
173
11
1,405
Athens/Greece
A set of four pucks plus felt both sides sounds nice!The extra block with another set of feet is a bit "towering".
Is your beautiful turntable (Not.Analog?) secure up there?
Johnny Vinyl
May 16, 2010
8,570
51
38
Calgary, AB
The TT setup is actually very stable, and yes, it's an N.A. Horizon SE.
Johnny Vinyl
May 16, 2010
8,570
51
38
Calgary, AB
No longer playing hockey, but I wonder how the softer plastic/rubber practice pucks would work instead of the harder game pucks?
Never let a geek think about a tweak... :D - Don
I used game pucks Don! Nothing but the best for me, baby!:eek:
DonH50
Jun 22, 2010
3,952
312
1,670
Monument, CO
:) I was actually thinking the slightly softer practice pucks might dampen things better. I think you should do some trials. Also, I'd like to know what colour works best... :D
Johnny Vinyl
May 16, 2010
8,570
51
38
Calgary, AB
(Looks for change in his pockets to see if such a purchase is doable...damn, this is getting expensive!):p:)
John
garylkoh
Sep 6, 2010
5,599
225
1,190
Seattle, WA
www.genesisloudspeakers.com
Different hardness would definitely make things sound different. Back when I had a Rega, I used squash balls (don't know if there's an equivalent in North America) under the Ikea butchers block as a suspension. There war various hardness for squash balls so tweaking with placement and mix of hardness was a good month's entertainment. I used rubber ring gaskets used in plumbing to make sure the balls didn't roll around.
