Time to remove the tarnish from those HiFi Tuning Supreme fuses again
LL21
14,423
2,516
1,448
Has anyone confirmed this with the manufacturer that this was their intent with their logo? The schematic symbol for a diode is cathode to anode which means negative to positive and not "plus to minus." You would have to flip the fuse to the opposite direction if you expected that configuration.
This is from the manufacturers website..Hi-Fi Tuning. they actually provide measurements for each fuse based on 'Direction 1' and 'Direction 2'. They go on to say:
"There is a measurable difference in directivity of fuses. Mostly that will be due to the way
the melting wire is manufactured. The difference is in the range of 5 % . That is in the
range of variations due to the factoring process, but the difference is measurable with all
types of fuses.
The resistance of the fuse itself is dependent on the length and thickness of the melting
wire. At pure DC- resistance measurements, of the commercial available fuses, the solder
type with leads gives the best results. Worst results gives the fuse with a glass tube and
spiral shaped melting wire.
The high end fuses all give better results in conductivity, the cryogenically treated fuses
from HiFi -Tuning give the best results, while the rhodium coated fuse from Padis gives
the highest DC- resistance..
For DC applications it´s recommended to use the solder type fuse or the cryogenically
treated fuses from HiFi-Tuning Germany..."
budda
22
Norway
Has anyone tried Cardas Contact Conditioner on the fuses.That should leave a conductive oil film on the contact aerie and maybe help.
Cyclotronguy
78
13
313
N. CA
The various oxides of copper are conductive as opposed to say oxides of copper, which are not. That said, one could I suppose clean the fuse and then apply a very thin film of dielectric grease to the silver end caps.
Aoyama
13
Brazil
Hello,
I clean my fuse with polishing cloth and CorrosionX. First remove the corrosion with polishing cloth and then with corrosionX and again the polishing cloth to remove the excess.
[]s
GaryProtein
2,542
31
385
NY
We have a small typo here.
YES, a typo.
The oxides of SILVER are conductive whereas the oxides of copper are not.
Oxides of silver are also more self limiting in film thickness, while copper will corrode more deeply into the parent metal.
I'm still more than a little quizzical about a fuse having polarity with a 60 Hz current.
Chuck Lee
84
7
238
Twice a year I clean my HiFI Supremes with Caig De-Oxit.
Then I apply a thin coat of Walker Extreme SST silver paste to the areas of the fuse that make contact with the fuse holders, which have also been cleaned with the Caig.
Twice a year to all contacts in the system isn't a big chore, it's like checking the smoke alarms.
About polarity,I have heard a difference in sound when the direction of the fuse is changed.Sometimes the arrows aren't an indicator of how to place them.
Where I thought the flow of electricity should follow the arrows, the sound was better the other way around.
What I heard as the correct direction, was when the sound took on a more full bodied, rounded dimension.
Not night and day differences, but audible just the same.
