Page 20 of 20 FirstFirst ... 1011121314151617181920
Results 191 to 196 of 196
Thread: Music Server Project
  1. #191
    Member JoeyGS's Avatar
    Join Date
    Jul 2011
    Location
    Laguna, Philippines
    Posts
    46
    Since SSD are expensive, will the performance be the same if a lower capacity SSD is used just enough for the OS and the softwares plus external HDD?
    Luxman PD 441, Technics SL1210 M5G, Modified MF VLPS with Cinemag SUT, iFi Audio iPhono 1 & 2, CAPS Zuma V3 Windows 2012 R2/Audiophile Optimizer 2.0/JRiver MC, iFi USB Power, Light Harmonic Geek Pulse DAC/Linear Power Supply, DIY CD ROM, 6922 Aikido w/ Lightspeed as Volume Attenuator, Lightspeed, 150w Gainclone Monoblocks, DIY Mark Audio Chr70.3 on Pensil Baffle, DIY Mark Audio Alpair 10.3M on Frugel Horn XL Baffle, Magnepan SMGc
  2. #192
    WBF Technical Expert (Speakers & Audio Equipment)/Member Sponsor [Technical Expert] garylkoh's Avatar
    Join Date
    Sep 2010
    Location
    Seattle, WA
    Posts
    5,417
    Hi Joey,
    I have not done an extensive, very serious, blind comparison, but based on my impressions, the new (Jan 2012) laptop server with a USB external HDD and a USB DAC, the old server (Oct 2010) sounds better with USB DAC and eSATA external HDD.
    __________________________
    Gary L Koh, CEO and Chief Designer,
    Genesis Advanced Technologies
  3. #193
    Join Date
    Jul 2011
    Location
    Laguna, Philippines
    Posts
    46
    Hi Gary,
    How about laptop with i3 processors, are they ok as music servers? There preowned units for sale and would like to know if it will serve its purpose for Hifi music use.
    Regards,
    JoeyGS
  4. #194
    Join Date
    Sep 2010
    Location
    Seattle, WA
    Posts
    5,417
    That might work just fine if there is a way to reduce the speed of the CPU so that the fan doesn't kick on. Since they are pre-owned, you should be able to check it on the BIOS set-up screen if it is possible.
  5. #195
    Join Date
    Jul 2011
    Location
    Laguna, Philippines
    Posts
    46
    Thanks Gary for being responsive to my queries.
  6. #196
    Join Date
    Sep 2010
    Location
    Seattle, WA
    Posts
    5,417
    For those of you using an iPad with Remote to control the original server or the laptop server, Remote 2.3 released by Apple breaks TouchRemote because of a tighter implementation of Fairplay. So, if you don't need it, do not upgrade from Remote 2.2. There is supposed to be a temporary fix, but I haven't been able to get it to work.
Similar Threads
  1. Linux music server 105
    By Vincent Kars in forum Vincent Kars On Computer Audio
    Last Post: 09-06-2011, 01:58 AM
  2. Music Server my way
    By Wardsweb in forum Computer Based Music Server Forum
    Last Post: 06-22-2011, 07:16 PM
  3. New Classical Music Server
    By RBFC in forum Computer Based Music Server Forum
    Last Post: 05-31-2011, 10:18 PM
  4. Mach2Music MacMini Music Server
    Last Post: 03-28-2011, 02:02 PM
  5. Olive HD Music Server
    Last Post: 12-09-2010, 08:43 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
