Page 15 of 20 FirstFirst ... 567891011121314151617181920 LastLast
Results 141 to 150 of 196
Thread: Music Server Project
  1. #141
    Member Sponsor [WBF Founding Member]
    Join Date
    Apr 2010
    Posts
    9,483
    No, no more crashes. I swear nothing is going right today! My Iphone signal to AT&T is so weak in my house, it can't get out on the web. I have a wireless router which my laptop is connected to right now and it works fine. Iphone finds the wifi network and says it connected, but yet it still tells me I have no service! I don't get it. Also, how do I set up a virtual hotspot on the computer?
    I disconnected the Iphone from the wireless network and was able to get a signal so I'm in the process of downloading the remote app to the Iphone. I still don't have a clue on how to set up the laptop to be a hotspot. It looks like it is going to take some software to make that happen?
  2. #142
    Join Date
    Apr 2010
    Posts
    9,483
    This is starting to get on my last nerve. I have downloaded the remote app to my Iphone. I have downloaded two separate programs to turn the laptop into a virtual hotspot. The first was Connectivity, but the free version doesn't work of course. The second one was Virtual Router. But virutal router needs a "certified for windows 7 wireless driver."
  3. #143
    Join Date
    Apr 2010
    Posts
    9,483
    I got if figured out somehow. I had to download some Intel drivers, run some commands from the administrator prompt, and now my Iphone controls foobar. That will beat the hell out of getting down on on my knees behind my left speaker where I currently have my laptop sitting on a wooden box that is filled with sand.
    I still don't think I have Foobar optimized though.
  4. #144
    WBF Technical Expert (Speakers & Audio Equipment)/Member Sponsor [Technical Expert] garylkoh's Avatar
    Join Date
    Sep 2010
    Location
    Seattle, WA
    Posts
    5,417
    Mark - the last paragraph on my instructions detail how to set up a Virtual Hotspot. It's an undocumented Windows 7 command - [netsh].
    I'm glad that you got it working with your iPhone! For the Emu 0404, try a Buffer Length of 480ms (it's not recommended by Foobar, but different buffer lengths below 1000ms sound better). [File] - [Preferences] - [Playback] - [Output].
    Also, try both WASAPI and ASIO. They sound different, but WASAPI doesn't seem to work at anything higher than 24/96 and the Emu ASIO is not certified for Windows 7 and seems to crash every now and then.
    __________________________
    Gary L Koh, CEO and Chief Designer,
    Genesis Advanced Technologies
  5. #145
    Computer Audio [Technical Expert]
    Join Date
    Jul 2010
    Posts
    860
    Quote Originally Posted by garylkoh View Post
    -- but WASAPI doesn't seem to work at anything higher than 24/96
    No, this has nothing to do with WASAPI
    Win supports USB audio class 1.
    This is tied to USB 1 (full speed).
    The payload of full speed is insufficient to play the next higher sample rate (2 ch 24/176)
    You need USB audio class 2 (USB 2 high speed) to play anything > 24/96
    This is not supported by M$.
    You need a third party USB audio class 2 driver or ASIO to play > 24/96
    http://thewelltemperedcomputer.com/KB/USB.html
  6. #146
    Join Date
    Sep 2010
    Location
    Seattle, WA
    Posts
    5,417
    Quote Originally Posted by Vincent Kars View Post
    Sorry, what I mean to say is that the EMU-0404 does not work with WASAPI at higher than 24/96.
    I was using a USB DAC at CES that supported WASAPI at 32/384.
  7. #147
    Join Date
    Apr 2010
    Posts
    9,483
    Gary-Thanks so much for all of your help! I still need to optimize foobar, but at least I was able to get my Iphone to sync with the laptop. I don't know if I could do it again though! I have been building my own computers from scratch since the early 1990s and I'm pretty good at the hardware side of things. Software-not so good. I felt like Forest Gump after he tore down his M-16 and put it back together in a few seconds and his drill sargent said, "Gump! You're a Gotdamn genius!."
  8. #148
    VIP/Donor [VIP/Donor] microstrip's Avatar
    Join Date
    May 2010
    Location
    Posts
    13,430
    Gary,
    I have now read your excellent detailed instructions on your music server and the followups in WBF. You choose to use Foobar versus JRiver because of sound quality or convenience? .
  9. #149
    Join Date
    Apr 2010
    Posts
    9,483
    I bragged too soon. Foobar crashed hard. It wouldn't even let me restart it in safe mode. I had to reboot the computer which of course meant I lost the commands I entered in the admin command box. Foobar did restart after the reboot and somehow I still have some connectivity between my Iphone and Foobar.
    Gary, the commands you listed in your instructions are different than the commands I found on the web. After I rebooted, it would no longer accept the commands it previously did which makes no sense to me. I will try your commands tomorrow.
  10. #150
    Join Date
    Apr 2010
    Posts
    9,483
    Almost everything seems to be working fine and how I have no idea why. I will master this yet. I lost the album art on Art Pepper, but Waltz for Debby is still there (I haven't run through the rest of them yet) and I don't understand that.
Similar Threads
  1. Linux music server 105
    By Vincent Kars in forum Vincent Kars On Computer Audio
    Last Post: 09-06-2011, 01:58 AM
  2. Music Server my way
    By Wardsweb in forum Computer Based Music Server Forum
    Last Post: 06-22-2011, 07:16 PM
  3. New Classical Music Server
    By RBFC in forum Computer Based Music Server Forum
    Last Post: 05-31-2011, 10:18 PM
  4. Mach2Music MacMini Music Server
    Last Post: 03-28-2011, 02:02 PM
  5. Olive HD Music Server
    Last Post: 12-09-2010, 08:43 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
