Page 13 of 20 FirstFirst ... 34567891011121314151617181920 LastLast
Results 121 to 130 of 196
Thread: Music Server Project
  1. #121
    WBF Technical Expert (Speakers & Audio Equipment)/Member Sponsor [Technical Expert] garylkoh's Avatar
    Join Date
    Sep 2010
    Location
    Seattle, WA
    Posts
    5,395
    Actually, it happened almost as many times the other way around. They would be saying to each other how quiet, dynamic and clean the digital was and then I'd walk over and take off the record and the music stopped. I would say that there were equal numbers of analog cliques and digital cliques walking around this way. It was very nice, though, that this year I had quite a number of father&son visitors.
    __________________________
    Gary L Koh, CEO and Chief Designer,
    Genesis Advanced Technologies
  2. #122
    Member Sponsor [WBF Founding Member]
    Join Date
    Apr 2010
    Posts
    9,483
    Gary-I'm having some issues with foo_touchremote. It keeps crashing foobar. It's only installing one dll. I have tried 3 different versions and they all crash.
  3. #123
    Addicted to Best! rbbert's Avatar
    Join Date
    Dec 2010
    Location
    Reno, NV
    Posts
    3,406
    Is Foobar a "memory" player? Would something like JRiver or Jplay sound better?
  4. #124
    Join Date
    Apr 2010
    Posts
    9,483
    Quote Originally Posted by rbbert View Post
    I don't know. All I know is that Foobar sounds damn good.
  5. #125
    Join Date
    Sep 2010
    Location
    Seattle, WA
    Posts
    5,395
    Quote Originally Posted by mep View Post
    Mark, here's where to download the Touch Remote: http://wintense.com/plugins/foo_touchremote
    It's a zip file and it contains foo_touchremote plus 3 more .dll files. It is now a full DACP server. You have to install all four .dll files into the components directory of your foobar installation.
    Please keep me posted with any and all problems. I'll make sure to update the instructions.
  6. #126
    Join Date
    Apr 2010
    Posts
    9,483
    Thanks Gary. I will try this tomorrow and see if I can get it to work. I appreciate the time you took to write the article. I'm looking forward to seeing if there any differences between XP Pro and Win 7 with regards to sound quality. Not to mention the hundred or so changes you had me make to the software!
  7. #127
    Join Date
    Sep 2010
    Location
    Seattle, WA
    Posts
    5,395
    You mean you didn't listen at every change to see if you can hear a difference??
  8. #128
    Computer Audio [Technical Expert]
    Join Date
    Jul 2010
    Posts
    860
    It isn't.
    But some use it this way by increasing the buffer to a size big enough to contain the entire track.
    As I don’t use Foobar can’t tell you the specifics.
    Maybe this link is of use: http://www.hydrogenaudio.org/forums/...p?showforum=28
  9. #129
    VIP/Donor [VIP/Donor] microstrip's Avatar
    Join Date
    May 2010
    Location
    Posts
    12,266
    I have now bought and I am using dBpoweramp to rip some of my CDs. All my rips have been accurate, but most of them show a very low number of matches - around 4 or 5 in classical music. Does this indicate that the number of registered users is very low? The maximum match grade I could see was 92 with "Buena Vista Social Club".
  10. #130
    Join Date
    Jul 2010
    Posts
    860
    Quote Originally Posted by microstrip View Post
    The number is indeed the amount of rips having the same checksum as yours
    Pop music is called pop because it is popular.
    Classical music is not popular so you will find a far lower number.
Similar Threads
  1. Linux music server 105
    By Vincent Kars in forum Vincent Kars On Computer Audio
    Last Post: 09-06-2011, 01:58 AM
  2. Music Server my way
    By Wardsweb in forum Computer Based Music Server Forum
    Last Post: 06-22-2011, 07:16 PM
  3. New Classical Music Server
    By RBFC in forum Computer Based Music Server Forum
    Last Post: 05-31-2011, 10:18 PM
  4. Mach2Music MacMini Music Server
    Last Post: 03-28-2011, 02:02 PM
  5. Olive HD Music Server
    Last Post: 12-09-2010, 09:43 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
