Page 11 of 20 FirstFirst ... 234567891011121314151617181920 LastLast
Results 101 to 110 of 196
Thread: Music Server Project
  1. #101
    Banned
    Join Date
    Apr 2010
    Location
    Seattle, WA
    Posts
    16,044
    Quote Originally Posted by mep View Post
    I wish that someone would give some step-by-step instructions on how to set up a computer music server to use with an IPad starting with the computer not having any wireless capability. I use Foobar now and I want to be able to control it from my listening chair.
    I was just reading exactly that, based on software Gary was talking about: http://techie-buzz.com/how-to/conver...00-remote.html
    I hope to test all of this and write our own tutorial on it.
    Gary, thanks for the information. I have tried other things that just didn't work. I am going to put this through its paces.
  2. #102
    WBF Technical Expert (Speakers & Audio Equipment)/Member Sponsor [Technical Expert] garylkoh's Avatar
    Join Date
    Sep 2010
    Location
    Seattle, WA
    Posts
    5,409
    Quote Originally Posted by amirm View Post
    The first few versions of foo_touchremote were extremely buggy, and not only hung the iPad, but it also hung the server often. The latest version I have not managed to hang yet.
    My music servers all don't have wireless capability - because I found that the built-in wireless degraded the sound quality so here's how I go about setting up:
    1. At an Internet-connected computer, download Bonjour Print Services from the Apple website, and foo_touchremote at Wintense.com
    2. You will need a wireless router and I'm assuming that your music server has an ethernet port
    3. Install Bonjour and foo_touchremote you just downloaded on the music server (I use a USB stick to transfer the files)
    4. Plug in the wireless router to the music server using one of the downlink ports. This will create a new WiFi network that is not connected to the Internet
    5. You may need to configure the router to give it a name that you can easily find with the iPad
    6. In the iPad, connect to the Internet and download the Remote app from the iTunes store
    7. Under "Settings" on the iPad, choose the wireless network that you just set-up in Step 5
    8. On Foobar, go to [File] [Preferences] [Media Library] [Footouchremote DACP Server] click [Add a new device]
    9. On the iPad, click the Remote App and click [Add iTunes Library] - it will display a 4-digit number which you will need to enter on the Music Server
    Hope that works.....
    __________________________
    Gary L Koh, CEO and Chief Designer,
    Genesis Advanced Technologies
  3. #103
    Join Date
    Sep 2010
    Location
    Seattle, WA
    Posts
    5,409
    Here are a few screenshots of the iPad and foo_touchremote:
    Album view - with album window open
    Name:  Album View..jpg
    Artists view
    Name:  Artist View..jpg
  4. #104
    Member Sponsor [WBF Founding Member]
    Join Date
    Apr 2010
    Posts
    9,483
    Gary-It all made sense except for hooking up the wireless router by plugging in the wirelesse routher to the music server using one of the downlink ports. I have one ethernet connection on my server and that currently has a CAT-5 cable connecting it to my regular router which is connected to the internet. If you are saying the new wireless router won't be hooked to the internet, how does it plug into my server?
  5. #105
    Join Date
    Sep 2010
    Location
    Seattle, WA
    Posts
    5,409
    My music server is not hooked to the Internet, so it is not connected to a router. If your music server is already connected to your regular router, is that router also a wireless access point? If it is, then the additional wireless router is not needed.
  6. #106
    Join Date
    Apr 2010
    Posts
    9,483
    Gary-It's a wired router. I get what you are saying now. Your music server is not connected to the net. You download programs to a jumpstick and then load them into your music server. So what you were saying is to take a wireless router, leave it unconnectd from the net, and plug one of the router outputs into the ethernet connection on the server? In my case, I would have to buy a wireless router, plug that into the cable coming from my wired router, and then connect the wireless router into my computer.
  7. #107
    Join Date
    Sep 2010
    Location
    Seattle, WA
    Posts
    5,409
    Correct. In both cases, the wireless router is what connects to the iPad.
    With my server, there are no virus scanners, firewalls, etc. No protection for better sensitivity to the nuances of music Hence, I cannot keep it hooked up to the Internet.
  8. #108
    Senior Member fork's Avatar
    Join Date
    Aug 2010
    Location
    Bellevue, WA
    Posts
    189
    It took some time, but I was finally able to fully audition the Stealth Audio Player's sound. It's a good concept to have a music player without a GUI, to try to lessen the impact on the server. Foobar still trumped Stealth in my super-tweaked audio boot section. I suspect the reason is because my Wyred 4 Sound DAC has it's own custom WASAPI and KS drivers. With the Stealth I can't turn off the Windows Audio, Windows Audio Endpoint and Multimedia Scheduler services, which might be it's downfall. Maybe the Stealth is also using the Windows WASAPI? A superior player requires the superior underlying infrastructure. Going without a GUI is a big sacrifice of convenience (you have to make playlists or click through to the folder with the track you want); it causes you to listen to music differently (kind of like going back to a CD player). If you're listening with those service on anyway, the sound may be better. I might have been willing to sacrifice the convenience, but it had to result in better sound.
  9. #109
    Join Date
    Sep 2010
    Location
    Seattle, WA
    Posts
    5,409
    You mean a test to measure Jitter? If so, it is quite an expensive proposition. I have an Audio Precision analyzer which can measure it but I have never set it up to do so with Jitter. It is one of the things on my TODO list. Once there, I am happy to measure you all's boxes.
    Amir, did you ever get to this on your TODO list?
  10. #110
    Banned
    Join Date
    Apr 2010
    Location
    Seattle, WA
    Posts
    16,044
    Quote Originally Posted by garylkoh View Post
    I have not unfortunately. One of these days I will have to give it a try.....
Similar Threads
  1. Linux music server 105
    By Vincent Kars in forum Vincent Kars On Computer Audio
    Last Post: 09-06-2011, 01:58 AM
  2. Music Server my way
    By Wardsweb in forum Computer Based Music Server Forum
    Last Post: 06-22-2011, 07:16 PM
  3. New Classical Music Server
    By RBFC in forum Computer Based Music Server Forum
    Last Post: 05-31-2011, 10:18 PM
  4. Mach2Music MacMini Music Server
    Last Post: 03-28-2011, 02:02 PM
  5. Olive HD Music Server
    Last Post: 12-09-2010, 09:43 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
