Page 7 of 8 FirstFirst 12345678 LastLast
Results 61 to 70 of 79
Thread: iTunes or Looney Tunes? The great music server debate.
  1. #61
    Join Date
    Oct 2010
    Location
    South of Kansas City, MO
    Posts
    12
    Being new to this forum (and feeling lucky to have found it), I read all of this thread with interest since I would like to build a dedicated media server. The topic appeared to have turned into a PC vs. Apple debate which was inevitable. I build my own PC's since I have total control over component choices and purchasing -- am still running Vista 32 and never had a crash or driver issues and have some potent software running to support my digital darkroom hobby.
    I must ask a really dumb question -- WHY is it preferred or considered necessary to have a dedicated DAC between the music server and the preamp? In my case, I am using a pre-pro that has both analog pass-through as well as digital DSP and Lyngdorf Room Perfect. IF I want to use the Room Perfect corrections for the room, it must occur in the digital domain and it seems like a lot of conversions to go from digital to analog to digital and back to analog out to the amps when the pathway could have stayed totally in the digital domain until the final conversion to analog that is sent to the amps:
    digital (from music server) --> analog (in DAC) --> digital (in pre-pro for Room Perfect) --> analog (in pre-pro) and out to the amplifers [so many conversions??]
    thanks,
    MikeSp
  2. #62
    Banned
    Join Date
    Apr 2010
    Location
    Seattle, WA
    Posts
    16,044
    Quote Originally Posted by MikeSp View Post
    MikeSp
    Not a dumb question at all. First, let me welcome you to the forum.
    Now to your question. You most definitely can go through your processor. Many of the people in this forum have dedicated 2-channel systems with no signal processing whatsoever so for them a DAC is the only thing they need to feed the rest of their analog system. Your case is different and you can certainly take the S/PDIF coax or Toslink optical from the PC and run it into your processor and use that for the rest of the chain.
    That said, a dedicated DAC is likely to have better performance than IC DACs in a processor of reasonable cost. So there may be slight improvement there. Unfortunately if you go back to digital domain in your processor, that improvement will likely be lost so in your case, I would say with the processor.
  3. #63
    Banned
    Join Date
    Apr 2010
    Location
    Seattle, WA
    Posts
    16,044
    BTW, while it is generally understood that optical TosLink has lower fidelity than Coax S/PDIF, I recommend per above to try both connections if they are both available. Optical link isolates the PC from the audio equipment and that might have a more positive effect than lower jitter on Coax connection.
    It is also eye opening to have both connected at once and switching between them and hearing a marked difference! Definitely makes the camp who thinks "digital is digital" think!
  4. #64
    [WBF Founding Member] Addicted to Best! JackD201's Avatar
    Join Date
    Apr 2010
    Location
    Manila, Philippines
    Posts
    10,816
    Who from PNWAS can get John Tucker in here? We had a discussion, well I tried to keep up but couldn't, about why he thinks iTunes is not up to scratch so he made his own. My feelings were hurt but what I heard at FIM's room at CES '08 with speakers, pre and amps I'm familiar with, made me think. If I wasn't such an analog hound lusting for the Technics R2R I might have paid closer attention, not that it would have helped me understand all the rocket scientist speak. I believe he did lots of work at JPL. He makes a darned good DAC too.
  5. #65
    Member Sponsor Addicted to Best! flez007's Avatar
    Join Date
    Aug 2010
    Location
    Mexico City
    Posts
    2,891
    Quote Originally Posted by amirm View Post
    Amir - i also thought that this was the case (toslink/coax) but in my system, the toslink route yields a more defined presentation, image and real-sized instruments compared to the coax output which is more warm but tends to colorate the signal... I wonder why?
  6. #66
    Computer Audio [Technical Expert]
    Join Date
    Jul 2010
    Posts
    860
    First of all if we talk about differences between SPDIF coax or Toslink we talking a bit of nonsense. We never hear the protocol, we always hear the implementation.
    Results therefore might vary depending on the components used.
    A badly implemented electrical SPDIF can generate tons of input jitter.
    However, these pictures demonstrated what is believed to be the case
    Obvious the jitter level of the Toslink is about 7 times higher than the coax but even 70 ps is a rather low value.
    Next question is how does our DAC copes with the input jitter of these connections.
    Often DACs do have their means like PLLs to reduce the input jitter.
    It is possible that both connections remain below the audible threshold of jitter.
    http://thewelltemperedcomputer.com/K...fectJitter.htm
    If this is the case, the complete galvanic isolation as offered by Toslink might have an advantage as no stray signals can disturb the DAC
    Source: http://www.hometheaterhifi.com/blu-r...r.html?start=1
  7. #67
    Quote Originally Posted by Vincent Kars View Post
    One might even go so far as to say it is likely that both connections remain below the audible threshold of jitter. If one happened to be just a bit skeptical of things heard by audiophiles straining to hear things that are only heard by audiophiles, one might say that unless the design or the execution is pretty screwed up, it is almost certain that both connections remain below the audible threshold of jitter. Then one might say buy decent digital equipment with the connections that are convenient, but I digress....
    Tim
    In high-end audio, you can't even fight an opinion with the facts.
  8. #68
    Banned
    Join Date
    Apr 2010
    Location
    Seattle, WA
    Posts
    16,044
    Quote Originally Posted by flez007 View Post
    I touched on the reasons why. PC typically has a horrible ground. It has a processor running at microwave frequencies pounding on it. It has untold number of clocks running, banging on the same rail. And of course, lots of RF radiation, all of which bleeds through that ground connection to your audio system. Some of these also act as jitter while others are analog interference screwing up reference circuits in your DAC, etc. So it is not surprising that optical which isolates this connection, helps a lot.
    Another solution if you have a pro card and DAC is to use AES balanced digital connection. Even here, you want to do an A/B to be sure you pick the one you like.
  9. #69
    Banned
    Join Date
    Apr 2010
    Location
    Seattle, WA
    Posts
    16,044
    Quote Originally Posted by Phelonious Ponk View Post
    Tim
    Tim, as I just described, there are lot more reasons for distortion other than jitter. I won't rehash everything discussed in the jitter thread either. I will say this though: you have a hypothesis that these two links sound the same. Why not go and see if you can prove it to yourself? Connect both to a PC and switch between them. Then come back and report what you heard. I have done this many times and the differences can be surprising. It shocked the hell out of me the first time I heard it as I wasn't prepared at all for what I heard. This doesn't mean I didn't have bias but it was an educational experience. I am suggesting you go to the same school .
  10. #70
    Banned
    Join Date
    Apr 2010
    Location
    Seattle, WA
    Posts
    16,044
    We are not talking about that topic in general. We are talking about them in the context of a PC being the source. It makes a difference.
    Right and hence the reason if people have both connections, they should simply test them and not make assumptions that are not transportable to their situation. To wit, there is not a single measurement in the world for your PC driving your DAC. It might have 1000 times more jitter than Oppo and you wouldn't know it.
    This is the case of one test and one player. It has no bearing on all cases and those involving PCs.
    PLLs are not a panacea. The analogy in the article is correct but doesn't work in digital world as a system. A digital playback system must maintain the timing of the samples as they arrive from the source. For example, if I send 41,001 samples/second because my clock runs that little bit faster, the DAC better reproduce that many samples or else, it gets out of sync with the source. If the DAC has to allow such timing change to be preserved, then how on earth does it know that deviation was not created due to jitter timing error? In real life, PLLs filter some amount of jitter but let others through. For example, they can opt to filter high frequency jitter because that is less likely to be created by the source on purpose.
    Please read the jitter debate thread where I showed that there is no published paper to give you comfort as far as audibility of jitter. See the second paragraph in the first post: http://www.whatsbestforum.com/showth...vs-Ethan-Winer
Similar Threads
  1. Music Server Project
    By PNWAS in forum The Pacific Northwest Audio Society Forum
    Last Post: 04-02-2012, 11:32 AM
  2. Music Server my way
    By Wardsweb in forum Computer Based Music Server Forum
    Last Post: 06-22-2011, 07:16 PM
  3. New Classical Music Server
    By RBFC in forum Computer Based Music Server Forum
    Last Post: 05-31-2011, 10:18 PM
  4. The Great Cable Debate
    By Steve Williams in forum General Audio Forum
    Last Post: 07-24-2010, 04:38 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
